| window vista | HELP! I have a virus... Hello! First of all, MOD or ADMIN feel free to move my thread to the appropriate forum please. First off, here is my computer LABTOP information: WindownVista Home Premium Service Pack 1 System: Manufacturer: Hewlett Parkard Model: Compaq Presario C700 Notebook PC Processor: Intel(R) Penttinum(R) Dual CPU 12370 @1.73 GHz Memory (RAM): 1.00GB System type: 32-bit Operation System My computer keeps shutting down and destroyed everything in the Control Panel. I'm using (IE & FF3) and they keep shutting down. I ran AVG and it shows that I have an infected virus "win32/Heur". I don't have anthying important saved on my labtop that I care about. I basically use it for surfing the net. I purchased it 4 months ago. My questions are:
| Vista Ultimate 64bit SP2/ | Re: HELP! I have a virus... Goto start menu/ Pc Help & Tools/ then Recovery Disc Creation you will need 2 DVD-R's and follow the instructions to make your recovery discs. |
| window vista | Re: HELP! I have a virus... Correct me if I'm wrong. I click on start>Help and Support>typed in PC Help & Tools. I can not find the Recovery Disc Creation anywhere. Must I purchase the Installation Disc? Thanks. |
| Vista Ultimate 64bit SP2/ | Re: HELP! I have a virus... Start menu/ all programs/ scroll down to pc help & tools/ then recovery disc creation |
| Vista Ultimate 64bit SP2/ | Re: HELP! I have a virus... ![]() Go here if its not in the start menu |
| | #6 (permalink) |
| window vista | Re: HELP! I have a virus... Mission accomoplished... Thank you very much. |
| | #7 (permalink) |
| Vista Ultimate 64bit SP2/ | Re: HELP! I have a virus... No problem bennys |
| virus | Vista mail | |||
| Virus or What? | Vista performance & maintenance | |||
| Virus??? | Vista file management | |||
| Got a virus alert on a virus that is over a year old | System Security | |||
| Help is it a virus | System Security | |||
