| Vista Home Premium 32bit. | Security Problem Hello everyone i'm use vista home basic. After i install SP1, many problem occur. I cannot copy file, cannot paste, cannot save file, cannot browse files. So, i restore my system. i think everything fine, but my system security does not working. I cannot Turn On the windows security, cannot use windows defender and cannot use windows update. When i try to open windows defender, this message out ; Application failed to initialize: 0x80070006. The handle is invalid. when i try turn on windows security; The Security Center service cant be started when i click check for update, this message out ; Error(s) found: Code 80070424 Windows Update encauntered an unknown error. Can someone help me to resolve this problem? Sorry, maybe my language not so good... |
| Vista Ultimate X64 SP2 | Re: Security Problem Sounds like you might have corruption (either user caused or malware caused). Try a restore to before the errors occured-if you have insufficient restore points you may to reinstall Vista, and if you are using a registry cleaner stop. They are nortotious for deleting critcal Windows components as they cannot discriminate between legitimate and unwanted items and this results in Windows/program file corruption. Check for malware here:Free ESET Online Antivirus Scanner |
| Security problem | System Security | |||
| Security problem | Vista General | |||
| Security Problem... | Vista security | |||
| Security Matters β Microsoft 2006 Security Summits Provide Security Training for Detroit Businesses | Vista News | |||
