| Vista Home Premium 32bit | HELP! mediaring talk has corrupted my PC hey guys im gonna be fast here. this has what happened. 1.my mum downloaded mediaring talk, you know its a bit like skypw. 2.well its slowed down my computer and its full of adds and bloatware 3.i went to programs and files on conrtol panels and tryed to uninstall it but its says it dosnt exist! 4.i had a look on the web and apparently it changes somthing in the regstry so you cant remove it 5.i need it gone i tryed removal tools but there as you to subsribe and i need help 6.its affecting my computers performance dangerously im prepared to go through the regstry and destroy it but im not sure what to get rid of? any help would be wonderful and i greatly appreaciate it lewismc |
| Vista Ultimatex64 Windows 7 build 7100 | Re: HELP! mediaring talk has corrupted my PC hey guys im gonna be fast here. this has what happened. 1.my mum downloaded mediaring talk, you know its a bit like skypw. 2.well its slowed down my computer and its full of adds and bloatware 3.i went to programs and files on conrtol panels and tryed to uninstall it but its says it dosnt exist! 4.i had a look on the web and apparently it changes somthing in the regstry so you cant remove it 5.i need it gone i tryed removal tools but there as you to subsribe and i need help 6.its affecting my computers performance dangerously im prepared to go through the regstry and destroy it but im not sure what to get rid of? any help would be wonderful and i greatly appreaciate it lewismc The problem here is that if you remove mediaring it will not remove the ad/bloatware. Try to uninstall all ad/bloatware that you can, in uninstall Programs Go here; Malwarebytes.org Down load and Install Malwarebytes, after the install run the program, go to the update tab and update it then do a full scan, if it finds any malware follow the instructions to remove it. Next Take note of the program names from the ad/bloatware that still starts. Click on the start orb, type msconfig in the Start Search click on msconfig.exe accept the UAC prompt, click on the Startup tab and remove the tick from all programs that you do not want to start with the computer. This may take some trial and error to get the right startup Programs, everytime you remove something you will have to do a New Start to see what has changed, so it is best to remove the Programs one or two at a time. If you turn off something that you need, then you can simply replace the tick on the next restart, after going back to msconfig. Click on the Services tab, put a tick in the box Hide all Microsoft services You can now turn off the services that are left showing this may take some trial and error to get the right services, everytime you remove things you will have to do a New Start to see what has changed so it is best to remove the services one or two at a time. If you turn off something that you need, then you can simply replace the tick on the next restart. NOTE after every New Start when you go back to msconfig You will need to put a tick in the box to hide the Microsoft Services, failure to do so could cause your computer to not Boot After you have done all this reply to the forum, let us know how you have gotten on. Hopefully most problems will be gone and we can then concentrate on any that are left including getting rid of mediaring and any other programs that are still causing trouble. I hope this helps Pooch |
| Vista Home Premium 32bit | Re: HELP! mediaring talk has corrupted my PC hey,i looked for media ring talk in the services tab its not there,as for malwarebyes i have scanned it full system scan about 3 times nothing its more of an add thing where like when you boot up it says "upgrade to 2.0 for only $45.99US and recive..." it comes up like every minute but so far in the last few days its stopped that im not sure what i did but i post back as soon as i have figured out.also what i realy want to do is just uninstall it from the computer but when i go to remove programs and click uninstall it says mrmediaringtalk could not be loacated,i looked around and aparently its been changing its name or somthing so you cant uninstall it.i was going to go through the regstry and remove i manualy but im not sure how i might accidently delete somthing important also i have no idea where to find it,oop's there its just poped up."upgrade now for only $45.99US!" thanks for suggestions -lewismc- |
| Vista Ultimate X64 SP2 | Re: HELP! mediaring talk has corrupted my PC hey,i looked for media ring talk in the services tab its not there,as for malwarebyes i have scanned it full system scan about 3 times nothing its more of an add thing where like when you boot up it says "upgrade to 2.0 for only $45.99US and recive..." it comes up like every minute but so far in the last few days its stopped that im not sure what i did but i post back as soon as i have figured out.also what i realy want to do is just uninstall it from the computer but when i go to remove programs and click uninstall it says mrmediaringtalk could not be loacated,i looked around and aparently its been changing its name or somthing so you cant uninstall it.i was going to go through the regstry and remove i manualy but im not sure how i might accidently delete somthing important also i have no idea where to find it,oop's there its just poped up."upgrade now for only $45.99US!" thanks for suggestions -lewismc- Whatever you do, DO NOT download the "mediaring removal tool" from the fake Antispyware 2009 site. Try Avast!, Avira, or NOD32 4 Antivirus (antivirus and antispyware), and Windows defender. SysInspector does a daignostic scan of your system, (startup/registry/running programs, etc)- anything in red is a problem. (green is good) its part of NOD32 4, but is also a free standalone download. Antivirus Scanners & Internet Security Tools Last edited by rive0108; 05-02-2009 at 08:01 PM.. |
| vista home premium | Re: HELP! mediaring talk has corrupted my PC do this: go to msconfig (type it into "start" search engine) then open msconfig - select Startup then disable all then click OK then restart computer then uninstall mediaring talk in the usual manner then enable all startups then restart computer MRT wont let you uninstall it while its running and that's the only way to prevent it from running whenever you turn on computer Please let me know if it works |
| Talk about hot... | Overclocking & Cooling | |||
| Wireless Vista laptop connection to Talk Talk | Network & Sharing | |||
| Can WLM talk to Mac iChat? | Live Messenger | |||
| Talk about WOW | Vista General | |||
