| Vista Home Premium 32bit | HELP! norton logo doing my head in! hey guys recently i've notice this anoying prick of a logo in my top left hand cornor of my desktop its from norton and probably just some friendly reminder that your protected or whaterever but i hate it and i want it gone how can a do this? i've added a thunmbnail below and you can see it quite clearly. |
| Windows 7 7600.16385 64bit | Re: HELP! norton logo doing my head in! Its not norton logo. seems like you are infected with some adawares or something. Try uninstalling norton and if you still see the logo, its a possible wallpaper hijack. Or simply try changing the desktop wallpaper. |
| vista home premium 32bit | Re: HELP! norton logo doing my head in! just google this and took me to the norton communty where the issue has been put down to a bug. i do also get this some time. Quote: It doesn't "mean" anything, it's a bug in the program where when we create the "toasters". Toasters are the little windows that show up some times when items are being processed etc... Sometimes when we create them, they are not hidden properly and you see what you are seeing, we have not been able to reproduce this behavior in house but have been trying to understand from the few that have seen it what is common amongst those systems. Matt Quote: There is no way to "hide" them, these are not supposed to be shown the way they are, this is a problem with the toaster part of the program. We are looking into ways to reproduce the problem and working on solutions for it. If you have a way to consistently reproduce the issue, we would like to hear from you. Thanks, Matt |
| Vista Home Premium 32bit | Re: HELP! norton logo doing my head in! dont worry it wasn't a virus just a "toaster" you can fix it by going to task manager and ending the problem or by upgrading to norton v3 to upgrade to v3 check my post or i'll submit a tortorial. |
| Getting Your Head Around 1 Trillion | Chillout Room | |||
| Maybe I'm a bit over my head ... | PowerShell | |||
| Head Scratcher | Vista mail | |||
| head and tail in PS? | PowerShell | |||
| Uninstall Norton Internet Security and Norton Antivirus | Vista installation & setup | |||
