Go Back   Vista Forums > Vista Forums > System Security
Vista - Spyware Issue
Old 05-28-2009   #11 (permalink)
Vista Home Basic 32bit
Re: Spyware Issue
Quote  Quote: Originally Posted by skunksmash View Post
Quote  Quote: Originally Posted by Bostonwolf View Post
Hello All;
Can someone recommend a good spyware program for Vista 64? I've tried PCTOOLS Spy Doctor. It ran and found spyware and removed it, however when I turned the computer on next it had boot errors. I ended up having to work with HP(very good help) and reload Vista from scratch. I hadn't backed up yet, but there was nothing to lose as the computer was one day old, just lost time.
Thanks in advance.
Hi Bostonwolf.....
'Spybot S&D'' ....used it for years, excellent app
SK
---I also wish to try that 'Spybot'/program---but that page lists 9 choices---which one do I 'download'?????---(it does not seem to describe in detail what EACH item does)---help?---
thank you
peace
Old 05-28-2009   #12 (permalink)
ultimate 64 SP1
Re: Spyware Issue
Quote  Quote: Originally Posted by kikidee View Post
Hello All;
Thanks in advance.
Hi Bostonwolf.....
SK
thank you
peace
here's the direct link........
spybot S&D
SK
Spyware are possible? Vista security
spyware Vista General
Spyware Vista General
