Go Back   Vista Forums > Vista Forums > System Security
Vista Tutorial - Spyware Issue
Old 05-17-2009   #1 (permalink)
Newbie
Vista 64 home premimum
Spyware Issue
Hello All;
Can someone recommend a good spyware program for Vista 64? I've tried PCTOOLS Spy Doctor. It ran and found spyware and removed it, however when I turned the computer on next it had boot errors. I ended up having to work with HP(very good help) and reload Vista from scratch. I hadn't backed up yet, but there was nothing to lose as the computer was one day old, just lost time.
Thanks in advance.
Old 05-17-2009   #2 (permalink)
im coming for cake
ultimate 64 SP1
Re: Spyware Issue
Quote  Quote: Originally Posted by Bostonwolf View Post
Hello All;
Thanks in advance.
Hi Bostonwolf.....
'Spybot S&D'' ....used it for years, excellent app
SK
Old 05-17-2009   #3 (permalink)
I Tunes hates Me
Vista Home Premium 64bit SP2
Re: Spyware Issue
im assuming it was pctools that screwed up your OS , what firewall/antivirus do you have? are you running windows defender?
Old 05-17-2009   #4 (permalink)
Newbie
Re: Spyware Issue
Thanks Skunk for the info and Archie: I'm using defender with Norton anti-virus.
Old 05-18-2009   #5 (permalink)
I Tunes hates Me
Re: Spyware Issue
then to be honest id be happy with that , less is more
defender is a malware blocker/detector and norton has one too , you have 2 there already
Old 05-18-2009   #6 (permalink)
Cross Stitch Queen
Vista Home Premium SP2 32bit / Windows 7 Home Premium 32 bit
Re: Spyware Issue
Another one that I use is SpywareBlaster, that isn't a scanner as such but stops the baddies putting bits in the register.
I've used it for several years in each new OS I've had
Old 05-18-2009   #7 (permalink)
Vista Home Premium SP1 32bit
Re: Spyware Issue
The MVPS website Dealing with Unwanted Spyware and Parasites recommends not to install Spywareblaster on vista.
Also see this thread.
Old 05-26-2009   #8 (permalink)
Limited Member
Vista Home Basic 32bit
Re: Spyware Issue
Quote  Quote: Originally Posted by RedDawn View Post
---thank you for the above info---(good thing that I actually read all of these posts even if I cannot help - but I learn from them!)---
peace
Old 05-26-2009   #9 (permalink)
Re: Spyware Issue
You're very welcome, kikidee .
Old 05-27-2009   #10 (permalink)
Newbie
Re: Spyware Issue
My thanks to all who gave me help. I went with the spybot and it seems to be working fine. It killed so many spyware issues it wasn't even funny.
Spyware are possible? Vista security
spyware Vista General
Spyware Vista General
