| | #11 (permalink) |
| Vista Ultimate 64-bit, SP2 | Re: AVG 8.5 Build 364 Vista 64 install problem Hi tasaholic [cider or beer? ] Guess it could be Morro you recommend to clients in the near future. |
| | #12 (permalink) |
| Vist Home Premium 64bit | Re: AVG 8.5 Build 364 Vista 64 install problem ran both of these: avgremoverx64.exe AVGIDPUninstaller.exe When I attempt to install AVG a msg prompts me that another AV is installed (which I can't find) and the installation continues. After several modules install you can see it then start to uninstall. The avgremoverx64 tool has a very long log created including a very detailed analysis of the registry in which it finds nothing installed from AVG. Stranger than science. |
| | #13 (permalink) |
| Vista Ultimate 32 bit; Vista Home Premium 32 bit ;Vista Home Premium 64 bit;Windows 7 . | Re: AVG 8.5 Build 364 Vista 64 install problem Morro will have to prove to be better than MS's previous attempts. Far better to stick to a program designed by dedicated security companies IMHO, JMH.I have found that the more 'advanced' the security programs become the harder they are to uninstall cleanly. I don't understand why most of the uninstallers do not do a clean enough uninstall, leaving too much junk behind. We should not have to go get cleanup tools everytime we uninstall these programs. |
| | #14 (permalink) |
| Vista Ultimate 32 bit; Vista Home Premium 32 bit ;Vista Home Premium 64 bit;Windows 7 . | Re: AVG 8.5 Build 364 Vista 64 install problem ran both of these: avgremoverx64.exe AVGIDPUninstaller.exe When I attempt to install AVG a msg prompts me that another AV is installed (which I can't find) and the installation continues. After several modules install you can see it then start to uninstall. The avgremoverx64 tool has a very long log created including a very detailed analysis of the registry in which it finds nothing installed from AVG. Stranger than science. |
| | #15 (permalink) |
| Vista Ultimate 64-bit, SP2 | Re: AVG 8.5 Build 364 Vista 64 install problem JMH.I have found that the more 'advanced' the security programs become the harder they are to uninstall cleanly. I don't understand why most of the uninstallers do not do a clean enough uninstall, leaving too much junk behind. We should not have to go get cleanup tools everytime we uninstall these programs. ![]() [Perhaps it's just "good" marketing. Make the innocent consumer terrified of changing to another "brand"] |
| | #16 (permalink) |
| Vista Ultimate 64-bit, SP2 | Re: AVG 8.5 Build 364 Vista 64 install problem Ugashik Bob, What a problem we have here involving Kaspersky, AVG & Avast! What a valuable lesson you are learning. [ Most of us have been in your current situation at some time, although not with 3 anti virus progs installed / uninstalled in fairly quick succession. ] I suggest your current options are 1.Do some computer "housework." [ disk cleanup, defrag, error checking ] 2.Get help from a tried & trusted local tech person near you. There is no shame in doing this. 3.If confident - Run in Safe mode - re run the 3 appropriate uninstall tools again. Reboot, 4.Delve into the registry via regedit. THIS CAN BE QUITE DANGEROUS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING. 5.Although I don't generally recommend registry cleaners, & if you MUST use one, I agree with tasaholic re CCleaner, but the slim build - CCleaner - Builds Good luck & please keep us posted. Last edited by JMH; 06-21-2009 at 08:06 PM.. Reason: Spelling. |
| | #17 (permalink) |
| Vista Ultimate 32 bit; Vista Home Premium 32 bit ;Vista Home Premium 64 bit;Windows 7 . | Re: AVG 8.5 Build 364 Vista 64 install problem @JBH [quote [Perhaps it's just "good" marketing. Make the innocent consumer terrified of changing to another "brand"][/quote] Hmmm...maybe you're right,it sure does cause some people a few hassles. |
| | #18 (permalink) |
| Vist Home Premium 64bit | Re: AVG 8.5 Build 364 Vista 64 install problem 1. Ran CCleaner Slim 2. Ran Ckdsk OK then cleanup then defrag. 3. Downloaded every AV uninstall pgm I could find. 4. Ran uninstall pgms again with AVG being the only one that really found anything. 5. Ran Windows installer Clean up and it detected nothing that appeared to be AV 6. Same with Revo uninstaller. 7. Ran AVG install with same errors. I live in a very remote area of Alaska and not anyone local. Appreciate the help here. |
| | #19 (permalink) |
| Vista Ultimate 64-bit, SP2 | Re: AVG 8.5 Build 364 Vista 64 install problem Well, after doing 1 to 6, your system should be free of remnants. [don't like 7 though. ] Time will tell. Is your computer stable & running smoothly? Alaska eh. The remoteness appeals, but the severe cold. Brrrrrrrrr! Good luck. [Please return if you have further questions.] Last edited by JMH; 06-23-2009 at 06:44 PM.. Reason: Additional point. |
| | #20 (permalink) |
| Windows 7 RTM 64-bit | Re: AVG 8.5 Build 364 Vista 64 install problem 1. Ran CCleaner Slim 2. Ran Ckdsk OK then cleanup then defrag. 3. Downloaded every AV uninstall pgm I could find. 4. Ran uninstall pgms again with AVG being the only one that really found anything. 5. Ran Windows installer Clean up and it detected nothing that appeared to be AV 6. Same with Revo uninstaller. 7. Ran AVG install with same errors. I live in a very remote area of Alaska and not anyone local. Appreciate the help here. BTW, if you are looking for a good free Av program, i will recommend go for Avast. |
| new build, vista install problems | Vista installation & setup | |||
| Vista wont install after new build | Vista General | |||
| Install problem with Windows Vista build 5744 RC2 | PowerShell | |||
| Build your own Vista install DVD | Vista General | |||
| A New Problem I am Having with Build 5308 CTP: No Programs will install on it (Except MBC)! | Vista General | |||
