Go Back   Vista Forums > Vista Forums > System Security
Vista - need help with my computer
Old 06-27-2009   #1 (permalink)
vista 32 i think
hey my computer is acting up, and i need help with it.
i have a dell xps 630i thats running windows vista. on friday, around 230 eastern time, my computer crashed. when i went to turn it back on tho, i saw something different with the dell writing, and the intel logo on the bottom right corner. they both were covered with dots eveywhere. After that screen passes by, i got a different new screen that i never got before. it was a phoenix awardbios screen. and below that it said, floppy disk(s) fail (40). never seen that before. when i try to start my computer up, i can either go to start up repair or start normally. when i do the start up repair( ive done it 9 times already) it says my computer cant fix the problem, and then i can either send or not the error report. and when i start it up normally, it goes to a blank screen. and then my computer goes into power save mode. anyone know whats up with it and how i can fix it.
Old 06-27-2009   #2 (permalink)
Vista home premium 64 bit
Re: need help with my computer
Sounds like your bios is corrupt.
On next boot go into your bios and check the date. Also check all the other settings if you know what thay are.
Do you have a floppy drive?
Old 06-27-2009   #3 (permalink)
vista 32 i think
Quote  Quote: Originally Posted by roy69 View Post
sorry im not exactly computer smarts... is that from hitting f2 or f12, or one of those, and no i dont have a floppy drive. i have a cd drive but that is all.
Old 06-27-2009   #4 (permalink)
vista 32 i think
also the date and the time are both correct. is there anything i can do to fix it?
thanks in advance
Old 06-29-2009   #5 (permalink)
Windows XP x86 Professional Service Pack 3, Windows Vista Ultimate x86 Service Pack 2 (VMware)
I worked with dell and I believe that's a case of failing video card. The floppy disks fail, man I've had so many of these calls, I really can't remember. Call technical support, it'll take 5 minutes. They know that issue to the last detail. "Thank you for calling Dell, Welcome to the XPS experience. My name is..." Whew miss those days.
Old 06-29-2009   #6 (permalink)
If you get no help from dell let us know.
Old 07-04-2009   #7 (permalink)
I guess he must have gotten help. As far as I remember it's a replacement graphics card that solves that one. With the floppy disks it's just some setting in the bios.
Exporting Windows Mail Messages from one computer to Outlook 2007 on another computer Microsoft Office
Exporting Windows Mail Messages on 1 computer to Outlook 2007 on another computer Vista mail
Can't view shared files on XP computer from Vista Home Premium computer Vista networking & sharing
How to setup Username/Password for a drive in a Windows XP computer to backup files from a Vista computer? Vista General
Placed an Order for a New Gateway Computer, a Windows Vista Ready Computer. Vista General
