| Linux | Virtual Machine?? Hey there i am complely new to the Virtual Machine thingy. So can anyone please be kind and mind explaning me what virtual machine is, what system requirement do i need to install it on vista 64 bit sp2?? And also, which is the best virtual machine(if there is any)? Thanks. |
| Linux | Re: Virtual Machine?? Bump! |
| Vista home premium 32bit | Re: Virtual Machine?? A little while ago I had produced this tutorial. Maybe it helps. ( Tutorial: How to install Windows7 in a Virtual Partition « How-To Geek Forums ). Although it was written for Windows7 in mind, I also ran Ubuntu in the virtual partition and you can run anything else that is supported. |
| error: Virtual PC could not open the Virtual Machine Network Servicesdriver | Virtual PC | |||
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| Re: WSUS 3.0 SP1 Running as a Virtual Machine in Virtual Server 2005 | Virtual Server | |||
| Unable to install Virtual Guest Services on virtual machine | Virtual Server | |||
| RE: Virtual PC could not open the Virtual Machine Network Services driver | Virtual PC | |||
