| vista home basic 32bit | problem hi two day ago my computer was attacked by advance virus remover (fake antivirus) and i managed to get rid of it but today after restart i couldnt open any program even ctrl+alt+delete didnt woked i did some stuff and now its working but only one problem on every program i run before it starts i get this error: ![]() any way to get rid of it??? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: problem Hello Scorp, To be safe, I would recommend to format and do a clean reinstall. Be sure to scan anything with a antivirus program before installing it on the fresh Vista installation just in case it was infected. |
| vista home basic 32bit | Re: problem format every one can do but i dont want to format so is there a way ti fix it without format? |
| Vista Ultimate 64-bit, SP2 | Re: problem You have been offered advice by an expert. I wouldn't disregard it lightly. |
| Windows 7 | Re: problem Try restoring your computer to a point, even before you installed that fake antivirus.. |
| | #6 (permalink) |
| vista home basic 32bit | Re: problem i didnt install it =_= it install it self and some why when i open system restore it says i dont have restore point but i do its seems that format is the best thing for now hmm i got an idea if i reinstall vista and addd to it that registry backup (from ccleaner) will alll the programs work (most of them on other hard drives, i got 3) |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
