| Vista Home Premium 64bit | help! Error on every startup loading dxrdiqif.dll,what does it mean? in msconfig the startup item is rxknvlcsu! |
| Vista 32 win 7 7600 32 bit | Re: help! Do you have an anti viruus app? current and running? What exactly does the error say? when in start up does it happen? ken |
| Vista Home Premium 64bit | Re: help! hi, i attached it here, i hope u can see it, there are 2 fishy ones from unknown manufacturers, u can see them here. i use avg free and its active and running, i just updated and scanned, it only found some tracking cookies which were healed. it says error loading dxrdiqif.dll and it comes when my desktop appears, everything else works just fine, my computer has not had any other symptoms at all. it started happening like 10 days ago. except once, i had a blue screen like 3 days ago and had to restart, but then after it worked fine. |
| Vista 32 win 7 7600 32 bit | Re: help! hi, i attached it here, i hope u can see it, there are 2 fishy ones from unknown manufacturers, u can see them here. i use avg free and its active and running, i just updated and scanned, it only found some tracking cookies which were healed. it says error loading dxrdiqif.dll and it comes when my desktop appears, everything else works just fine, my computer has not had any other symptoms at all. it started happening like 10 days ago. except once, i had a blue screen like 3 days ago and had to restart, but then after it worked fine. That file is in the 32 bit programs folder. do you have your search to index the whole drive or just sertain folders? Ken |
