Go Back   Vista Forums > Vista Forums > System Security
Vista - not able to use USB drive
Old 10-13-2009   #1 (permalink)
32bit
Hi!
i am having windows vista. I am having administrator rights. I can't use USB pen drives. when i put a pen drive, it starts installing drivers for pen drive and then gives me message "system policy restricts you to install drivers".
where to edit the policy so that i can install the drivers and use pen drive.
In hardware settings it shows USB drivers are installed and drivers are working fine.
Only thing is that it do not allow me to install device drivers. I think o need to change local policy, but i don't know which thing to enable
thanks
amit
Old 10-13-2009   #2 (permalink)
Vista 32 win 7 7600 32 bit
Re: not able to use USB drive
Amit
Im not sure but a good place to start would be in group policy. type gpedit.msc
Combo RAID1 and standard Drive setup problem - Unallocated Drive General Discussion
Access XP data drive using Vista Ult (XP drive=slave drive only NO Vista account administration
Problems installing Vista on SATA drive as third master drive Vista installation & setup
Vista on the C: drive but System drive is the D: drive - any way to Vista installation & setup
Vista maping drive to server 2000 shared drive not recognize user/ Vista networking & sharing
