Possible malware not shure
Vistaftw
Well after I had made another adminstrator account which I dident mean to I had logged in to my account I always use and had no sound,no Internet connection, my whole start menu bar looked like I was in xp which I'm not. So I wanted to know if restore will I still have this problem. I have 2 restore disk they gave me when I bought my computer.
Tryed the last know dident work
Tryed system restore when i clicked it the window won't even open just stays as if I never clicked on anything if I right click that menu won't even pop up :( :cry:
If you use the restore dvd you will lose all your documents, programs have to be reinstalled etc.
Go into safe mode f8 on boot. Then try to do the system restore from there.
If I go into safe mode do system restore I have this error that comes with an error can't remeber exatcly what error it was but in the message it would say try to use system restore at another time
If you have a laptop follow the instructions and go back to factory specs.
Laptop Recovery Instructions - Tech Support Forum
Your computer goes back to the way it was the day you brought it home.
Which is what happens with the recovery DVD.
If that is all you have I would give it a try. Remember, you go back to the way it was the day you bought the computer. No programs etc.
LOL, had to look at the post. She means the start button. Lower left of monitor. You are not a noob, I did not know what she meant until I saw it in context.
The only restore point that you can make is of the present. That will not help since, the problem exists in the present.
Try last known configuration again, it may work now. You did some repairs to System Restore. But I have doubts. I am trying my best to avoid using the DVD, that will bring you back to day one. No programs or anything.
