Solved Is it possible to disable UAC for specific programs?
Dick Jagger
First, I added the three programs in the pic to the start up folder, but they get blocked. I have to manually run each one and then accept the UAC. So, I next tried adding to the task scheduler and running at log on, but they still bring up the UAC.
IS there a way to accomplish this for these programs?
Core Temp;
HD Tune;
ZoneAlarm
    Acer Aspire 4730Z
    Intel Pentium Dual CPU T3400 @ 2.16GHz
    Acer Aspire 4730Z
    3001 MB
    Mobile Intel GMA 4500M
    B141EW04 V4 30 cm x 19 cm (14.0") 5:3
Yes, I'm aware of that option, but that is overkill. I want to selectively disable the feature for programs that I want to have run at log in. My guess is that these ^ programs are not signed by Microsoft.
    Acer Aspire 4730Z
    Acer Aspire 4730Z
    3001 MB
Hello Dick Jagger.
Have a look at the tutorial at the link below to see if it'll work for you; be sure to post back to keep us informed. It is a very bad idea to disable UAC, if you do so any maleware that gets into your system will have free access to do whatever it wants with no warning to you.
Elevated Program Shortcut without UAC Prompt - Create - Windows 7 Forums
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
    Acer Aspire 4730Z
    Acer Aspire 4730Z
    3001 MB
Hello Dick Jagger.
Try putting the shortcut created with this in the startup folder; let me know if it works, you may need to leave the original on the desktop and put a "copy" of the shortcut in the file for it to work.
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
^ Awesome! That definitely works... combining the UAC task shortcut with the start up programs instead.
I now only have the ZoneAlarm Client being blocked by Defender at startup, but the Zone Alarm.exe program actually runs fine(and without UAC) anyway using your suggestion. Thanks.:)
    Acer Aspire 4730Z
    Acer Aspire 4730Z
    3001 MB
Hello again.
I'm glad you found a solution that works for you; thanks for the update.
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
One of the programs that I was able to have run at startup without UAC prompting, CoreTemp, starts with the program interface displayed and in the system tray. I'd like to have the program start minimized or hidden. I have tried to have it run minimized but that doesn't work - I still have to select File > Show/Hide. I have also added "-hide" as a parameter in the target of the shortcut, but this also doesn't work. Is there a way to accomplish this? THanks.
    Acer Aspire 4730Z
    Acer Aspire 4730Z
    3001 MB
Hello again.
Is that the same behavior when the app is started regularly?
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
