System recovery doesn't work...
johnyi
problem : System restore disabled by group policy. i have vista home basic so gpedit.msc dosent work...
This is what i've tried
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
Problem is, itried to delete the DisableSR but it dosent delete and Disableconfig isnt even there..
HELP PLEASE
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device.
    One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
Hi i dont have a vista disk though.. is there any way i could do it without requiring that? Im still puzzled on why it wont let me delete DisableSR and why disableconfig isnt even there.. :(
Did your Vista come pre-installed on your computer? What brand of computer, if it did?
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
You're welcome, and good luck! :)
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
It will fit on cd easily, or you can put it on a flash drive, instead.
If you don't have access to any of those:
As the iso is small, you can boot the iso direct off the HD - suggest you put it on another partition and use Easybcd beta to put the boot menu entry in for you.
Very easy,
Just click Add new entry, click the Iso boot tab , select run from memory in the drop-down.
Then browse to the iso you downloaded and click add entry.
Restart the pc and select Neosmart isoboot from the menu.
EasyBCD 2.0 Beta Builds - The NeoSmart Forums
This is beta- don't worry I have tested it and the isoboot function you want works well. You need to sign up to the Neosmart forum to d/l - it's free.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Very easy,
Or you can just log in with this:
Username: Tex
Password: qwertzuiop
I just checked that and it worked :) This isn't my account, and I have certainly not taken somebody elses. I got it off the following website, where users can upload their free website credentials so that others can log in when they need to:
NEOSMART.NET passwords - login with these free accounts to bypass compulsory web registration - Bugmenot.com
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
There are reasons Mahmoud wants people to sign up ( it's free ).
It's a beta product and is important to read the disclaimers.
Also it helps the site - hits and membership numbers help to encourage advertisers and the consequent revenue - essential to defray the site running costs.
He develops the products and makes them available to all - free.
The least we can do is sign up. Donate as well, if you can.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
