Does malwarebytes slow down the pc
patch41
Vista Pro
Hi Folks , I have a friend who has a laptop 1g memory 65g hardrive 64 bit, I had installed malwarebytes, and also spybot as i think they are two good programs, and he had norton 360 which came free with his comcast subscription, another friend of his came along and removed norton said it was to heavy a program and installed free avg, he also removed malwarebytes and spybot, he said they slow down the computer to much,now i know if you are running anti-virus or malware, and you run a program at the same time it slows the program considerably, but if they are not running are they slowing down the computer just sitting on the hardrive.
thanks, patch41
Malwarebytes, the free version, will not slow the computer at all, except when doing a scan. The software uses little resources and the effect will be hardly noticed. You do not need the pay version if you have a good anti virus.
Norton is renowned for hogging the CPU so if you're looking for speed, then that's a good first step :) I don't think AVG is all that much better to be honest, there are far better programs out there
Malwarebyte's is a very light program - especially the free version as it doesn't offer real time protection. I would recommend that you remove all existing AV and anti spyware software on your system, and replace them with:
Microsoft Security Essentials
Malwarebytes' Anti Malware
MSE is nice and light, has good detection rates and works very well with Windows. MBAM also offers high detection and removal rates and should be used for weekly scans
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Hey Patch41 how are you doing, if I may give a couple of pointers my self. I know you will love these, a lot on the forum uses them.
1. Soluto will help speed up your logon time
2. Secunia PSI a must have
3. Winpatrol
I have had great service from all 3 and heres the best part it's FREE I know you did not want to pay so much, it's late here and I'm a little punchy, they are very good so at least check them out. Real glad to see you on the forum. LOL
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    HP Multimedia Keyboard
    Microsoft Wireless Mouse 5000
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
