Solved Malwarebytes problems....
nnj925
I posted a thread last week asking if anyone knew something I could use for free like Malwarebytes b/c my free trial was ending...they told me I must have downloaded the Purchase version with the "free trial first"...so I uninstalled it....(it had about 4 days left to expire)...and I re-installed it again ....(what said FREE VERSION) well now it just expired again today???
Is this going to keep happening if I keep reinstalling it??? When I would go to the Malwarebyte site to install it would always send me to a different site to download...It was very hard to find the actual "download"....So is there something I am doing wrong that this free trial keeps expriring???
Any help I would really appreciate....
Nicole
PS I am not very computer savvy so detailed info would be much appreciated. :)
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Major Geeks as well as the website that I suggested should both serve your needs. If you use either you should not have a problem. Did you do something differently?
Actually Major Geeks was where I downloaded from and it just expired with not even having it for 1 week....I just installed it again from cnet. this time...it was exactly the same as the one from major geeks......I just dont understand why it kept expiring....
If you used Major Geeks and you had a problem, somehow you clicked on a trial offer. If you now used CNET, and you used the top link, you should be ok.
If you need to do it again, read the fine print. You MAY have been given an option to tick off free, etc at the time of the download. Remember, they want to make money, so be careful.
Just had a thought,
Could it be after a week, they ask you to pay for the full version, but the free version still works?
Uninstall MBAM using RevoUninstaller (remove any leftover files found) then try installing MBAM
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Well I thought I uninstalled it 15 min ago...and re installed at cnet...I just re booted and malwarebytes popped up saying "your subscription has expired" meanwhile when I had uninstalled it earlier this morning it was gone??
Hold the
key and press R to bring up the run box.
In this box, copy and paste the following
Code:
cmd /c regedit.exe /e %USERPROFILE%\Desktop\tom982.txt "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"
Then press OK. This will create a text file on your desktop called tom982.txt. Open this and copy and paste its contents into your next post please
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
before I do that....I used the uninstaller link you provided above...but I hit restart after and not SCAN.....so I dont know if it worked??? I dont see it under the control panel....tho it think it was uninstalled?
Yes, it would have uninstalled it. I wanted to clean the remnants from the installation though.
Do the thing I previously suggested then once you've posted the log, try doing this:
3. Clear Temp Files
  • Download TFC (By OldTimer), to your desktop.
  • Save any open documents, then close any active programs/windows
  • Right click on the file, and select Run As Administrator
  • When it opens, click Start to being the process
  • A reboot is required upon completion of this, if this is not done by TFC then do so manually
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"RtHDVCpl"="RAVCpl64.exe"
"Skytel"="Skytel.exe"
"Apoint"="C:\\Program Files\\Apoint\\Apoint.exe"
"IgfxTray"="C:\\Windows\\system32\\igfxtray.exe"
"HotKeysCmds"="C:\\Windows\\system32\\hkcmd.exe"
"Persistence"="C:\\Windows\\system32\\igfxpers.exe"
"WPCUMI"="C:\\Windows\\system32\\WpcUmi.exe"
"acevents"="\"C:\\Program Files\\ActivIdentity\\ActivClient\\acevents.exe\""
"accrdsub"="\"C:\\Program Files\\ActivIdentity\\ActivClient\\accrdsub.exe\""
"BitDefender Antiphishing Helper"="\"C:\\Program Files\\BitDefender\\BitDefender 2011\\ieshow.exe\""
"BDAgent"="\"C:\\Program Files\\BitDefender\\BitDefender 2011\\bdagent.exe\""
I have no idea how Malwarebytes managed to run itself on startup. Try doing the TFC instructions :)
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Are you still getting this message when you reboot? If so, can you upload a screenshot for us to look at?
I've got the Pro version of MBAM, but even when I had the free version I didn't get any of the kind of messages you've been receiving.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
    Gigabyte IF233
This is NOT a "fresh" version...if by FRESH you mean one I haven't downloaded...I already did the Major Geek one...you posted I can never find the link there. Its eaiser at cnet...
Try the CNET, if you are more comfortable. Read any fine print. Be sure you are always with the free version. I used the CNET without any problem.
