Solved DEP Problem
lhardig
Hi Everyone,
I m new here so please excuse me if I do something incorrect.
I will learn as time goes by.
I'm hoping to here directly from Brink, the administrator, but would certainly appreciate any help from anyone, because I am totally stumped.
I disabled my DEP. Then I decided I might better enable it. I followed all the recommended processes but it still remains grayed out. It keeps telling me,
" The boot configuration data store could not be opened. Access is denied."
I am the only user on this computer and I am using the administrator account. I thought about putting my riginal disk inand see if I could correct it that way but was afraid I would lose the files on my documents file.
Please help me someone to correct this problem. I am at my witts end.
Thank ou very much for any help I may receive.
sincerely,
lhardig
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi Brink,
Thank you for moving my post to the right area. I see the correct place now.
Thank you for the answer page link you gave to me.
I did indeed find this page before and went thru it.
After rereaing it I realize I missed the, "UAC" portion.
I am thinking this will correct my problem but now must restart my computer for it to take effect. I just wanted to comeand thank you before I done that.
Have a great day and thank you for your time and effort.
I am much appreciative of your knowledge.
sincerely,
lhardig
Hi Shawn,
update......
The UAC was correct after all.
The problem seems to stem from the command prompt.
I needed to open it as the administrator then everything was bak to normal.
I know I did this before but obviously I must not have because it seems tohave fixed it this time around haha.
Just a polite thank you and I ake my hat off to you m8.
Cheers!
lhardig :)
You're most welcome lhardig. I'm happy to hear that you got DEP enabled again. :)
