terrible problems after malwarebytes scan
mo12
I have Vistas premium home 64 bit. Two days ago I noticed that my computer was running very slowly and freezing up. I did a scan with Malwarebytes free version as usual and it found 20 PUP opt.b infections which I removed. I then restarted the computer and found that when I clicked on Internet Explorer I could not connect to any websites at all including Outlook, Facebook, Ebay, Google nothing at all! So then I went back and found the list of items I had removed as a result of the scan and restored them all. Then Internet Explorer WOULD connect to the websites again. I did another scan and this time I removed all the PUP infections except for the ones that were found in memory, registry but after restarting I once again could not get to any websites at all. So again I restored all the PUP infections. Since then I can still get to websites but not all: I can't get to Bleeping Computer or any help type of forum which has helped me in the past. The last scan I did still contains all the infections because I was scared to remove them after that and my computer continues to run very slowly. I really need help in easy to follow instructions.
I just wanted to add that I just did another scan with Malwarebytes and the same infections (PUP opt.b) showed up. I took a closer look and saw that every one of them was connected to browser safeguard which I have no idea how that program got onto my computer. Anyway I went to the control panel and removed Browser Safeguard, did another scan and it came up perfectly clear of any infections! However I still have a slow computer and absolutely cannot get into Bleeping Computer which has helped me in the past. So I still need some help from this forum. Thanks!
Are you sure that you went back far enough. Go back a week before the problem.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    1 external eSATA LaCie 3TB
    (Non-RAID)
    Unique
    1gb/s up and down
