Vista Tutorial - Fonts - Change Default
Comment
Old 11-14-2007
Brink
Administrator
How to Change the Default Vista Fonts
Old 01-04-2009
Brink
Administrator
Re: Fonts - Change Default
O'Connel,
It should only change system settings and files, not your personal data. I would recommend to back up anything that you do not want to lose just to be safe though.
Old 01-12-2009
TPERKI3000
NEWJACK
Vista Home Premium 32 bit
WOW! Thanks for the info...Brink this information was useful.
Old 01-12-2009
Brink
Administrator
You're welcome TPERKI3000.
Old 01-16-2009
386sky
XP, Vista & Ubuntu
Microsoft Windows XP Professional Edition
How you should have installed the font that was bundled with mac, namely Lucida Grande, to c:\windows\fonts.
Old 01-16-2009
Brink
Administrator
Hello 386sky,
I'm not sure if a font from a Mac would work in Vista. Normally you would just drag and drop the font into that folder to install it.
Old 02-02-2009
OConnel
Newbie
Vista Ultimate x64
Hi!
So i still have fontproblems cuz i couldnt do this (i dont have any restore points)
If i insert my Vista disk can i do something(for example: Repair)?
Sorry for my Bad english
Old 02-02-2009
Brink
Administrator
O'Connel,
Did you already try the tutorial to see if you can change the fonts back to how you want them for each item?
If yes, then you may be able to do a Repair (upgrade) install instead of a clean install. See the NOTE box at that link to see if you can.
Old 02-03-2009
Deanooo
Newbie
Vista Home x64
I tried to change the font default from Times New Roman 10 to Arial 12 which was always so easy in XP but when I followed Brink's suggestion, regedit, did not succeed.
Old 02-03-2009
Brink
Administrator
Hello Deanooo, and welcome to Vista Forums.
If you mean from OPTION ONE (Step One), then you can only use the actual name of the font and not any size with it.
Were you not able to change them using Step Two?
Old 02-03-2009
Deanooo
Newbie
Vista Home x64
I would like to get rid of the Times New Roman default and make Arial my default. I would also like to change the font size from 10 default to a 12. I am new to Vista and didn't have this type of problem with XP. Thank you for posting.
Deanooo
Comment
Tutorial Tools
Tutorial Category
Solved Vista Default Fonts? General Discussion
How to: Extract Default Vista Fonts Vista file management
How to change these fonts? General Discussion
Reinstall Vista Default Fonts? Vista General
Fonts won't change General Discussion
