| Administrator | Notification Area - System Icons How to Enable or Disable the Notification Area System Icons in Vista Last edited by Brink; 04-22-2009 at 06:22 AM.. |
| Administrator | Re: Notification Area - System Icons Hi Jamdn, If you alread tried this tutorial to get back what I am assuming your Volume and Network icon, then reinstall your audio and network drivers to see if that will help. Hope this helps, Shawn |
| Member | Re: Notification Area - System Icons how do you reinstall your audio and network drivers? |
| Administrator | Re: Notification Area - System Icons Jamdn, What is the brand and model of your laptop? I'll post back with a link from the laptop manufacturer's website so you can download the drivers and reinstall them. Shawn |
| Member | Re: Notification Area - System Icons its an acer- thank you very much- im not the best with computers |
| Administrator | Re: Notification Area - System Icons Can you also include the model number? It should be on the bottom of the laptop somewhere. ![]() Shawn |
| Member | Re: Notification Area - System Icons 5100 series? |
| Administrator | Re: Notification Area - System Icons Ok Jamdn, I believe you have the Acer Aspire 5100 then. At the link below select Notebook, Aspire5100, and select the Realtek audio then the LAN network or wireless LAN network driver. http://www.acerpanam.com/flex/acerdr...TOKEN=72032399 Hope this helps, Shawn |
| Member | Re: Notification Area - System Icons thanks alot |
| Administrator | Re: Notification Area - System Icons Your welcome Jamdn. Shawn |
| Newbie | Re: Notification Area - System Icons I've tried all suggestions above and elsewhere to get the grayed out power back to no avail. How do I, "Make sure the the drivers and devices that go with the system icons are installed and working properly. They will not work if the device or driver does not." to see if this is causing my problem? |
| Tutorial Tools | |
| Tutorial | Category | |||
| How can I hide one or two system icons from Notification Area? | General Discussion | |||
| System Icons Missing in Notification Area!!! | Vista General | |||
| Desktop icons & Notification area issues | Vista General | |||
| Notification Area - Hide All System Icons | Tutorials | |||
| Missing icons from Notification Area | Vista General | |||
