Vista - Notification Area - System Icons
Comment
Old 11-16-2007
Brink
How to Enable or Disable the Notification Area System Icons in Vista
Old 02-22-2009
Fullmetal99012
Vista Ultimate 32bit
Re: Notification Area - System Icons
With my computer, the power icon appeared until i installed the APC manager. My other icons (volume, network) disappeared though. I am going to try a reeboot first, that usually helps with my problems.
Old 02-27-2009
jmt356
Windows Vista Home Premium 64 bit
Hello again Shawn,
After having reinstalled the registry files, the problem has not been resolved. You said that some security programs may interfere with these files, so I temporarily disabled Norton Antivirus, but the network icon continued to not appear and to remain absent in my Taskbar and Start Menu Properties taskbar. The only solution I have found has been to restart and that takes a long time and causes me to have to close down the many programs and files I usually have open.
Regards,
JMT
Old 02-27-2009
Brink
Hi JMT,
As a workaround for now, you might see if you can just end and restart the explorer.exe process to get it back without restarting the computer.
Restart Explorer
Old 03-01-2009
Travan
Vista 32 bit Business
Very good tutorial and really helped getting the icons back. Especially helpful was the 4 services that need to be enabled. Thanks again
Old 03-01-2009
Brink
You're welcome Travan, and welcome to Vista Forums. I'm happy to hear that you got it sorted.
Old 03-19-2009
joefrawley
vista home premium 32bit
Smile Re: Notification Area - System Icons
hey none of this worked for me i had to follow step three and when i downloaded the file and right clicked it there was no merge option and then when i went to regedit local machine ect. there were no files in there to delete well really there was nothing there under explorer at all so now im gonna run a system restore to like 3 days ago and see if that fixes it thanks any way looks like i good post if i could understand it.
Old 03-19-2009
Brink
Hello Joe, and welcome to Vista Forums.
Let us know if you need any further help on this.
Old 03-19-2009
bmf1990
Vista Home Premium 32bit
Hi there,
You can try to check thisMicrosoft Help and support page:
System icons do not appear in the notification area on a Windows Vista-based computer until you restart the computer
I did the manual fix and it worked just fine.
Cheers,
bmf
Old 04-01-2009
sonia
Vista Home Premium 32 bit
When I got to the final stage to enable my Sound and Network icons, the right side next to "Explorer" had only one entry "REG SZ Value not set". It looks like these system icons are no longer there. How can I re create them? All my other icons are back and working without problem.
Old 04-01-2009
Brink
Hello Sonia, and welcome to Vista Forums.
You can download and merge the reg files in METHOD THREE to had them added back automatically for you.
Comment
Tutorial Tools
Tutorial Category
How can I hide one or two system icons from Notification Area? General Discussion
System Icons Missing in Notification Area!!! Vista General
Desktop icons & Notification area issues Vista General
Notification Area - Hide All System Icons Tutorials
Missing icons from Notification Area Vista General
