Vista - Notification Area - System Icons
Comment
Old 11-16-2007
Brink
How to Enable or Disable the Notification Area System Icons in Vista
Old 04-02-2009
sonia
Vista Home Premium 32 bit
Re: Notification Area - System Icons
+Thanks Shawn - for the help and asap reply. Worked, and the icons are back in place.
Old 04-02-2009
Brink
You're welcome Sonia. I'm happy to hear that you got it sorted.
Old 08-31-2009
SnooGans
Vista Ultimate x64 SP2
Thanks for this Useful Tutorials. I gained enough information
Old 08-31-2009
Brink
You're welcome SnooGans, and welcome to Vista Forums.
Old 3 Weeks Ago
cyberbiker
Vista Home Premium 64bit
Question Re: Notification Area - System Icons
I have always found that a couple restarts restores icons, but now my power and "safely remove hardware" buttons are missing and don't seem to be coming back. First time I have lost the "safely remove hardware" button.
any one else missing it?
Old 3 Weeks Ago
Brink
Hello Cyberbike,
Have you already tried the tutorial on the first page to see if it can restore you Power icon? Do you have your battery connected to your computer?
The Safely Remove Hardware icon will usually only appear when you have a removable drive connected to your computer. As a workaround, you can use the shortcut below for it instead.
Safely Remove Hardware Shortcut
Old 3 Weeks Ago
cyberbiker
Thumbs up Re: Notification Area - System Icons
Thanks, Shawn. Your manual method at Notification Area - System Icons - Page 7 - Vista Forums worked perfectly. Just had to add the Explorer key to the registry. It made the "Safely Remove hardware" icon reappear and ungrayed the Power box in the Notification Bar Tab of the Task Bar Properties so it could be checked. Cheers.
Old 3 Weeks Ago
Brink
You're welcome Cyberbiker. I'm happy to hear that you have the icons back now.
Comment
Tutorial Tools
Tutorial Category
How can I hide one or two system icons from Notification Area? General Discussion
System Icons Missing in Notification Area!!! Vista General
Desktop icons & Notification area issues Vista General
Notification Area - Hide All System Icons Tutorials
Missing icons from Notification Area Vista General
