| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Control Panel Desktop Icon How to Change the Desktop Control Panel Icon in Vista |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Control Panel Desktop Icon Hello Ktrenta, and welcome to Vista Forums. I believe this is the icon package I got that control panel icon from below. VistaIcons.com - Download Alpha Dista Pack: Free Vista Style Icons, Free Icon Sets and Windows Vista Desktop Icons Can you post a screenshot of that registry location? I'll take a look at it to see if there is anything wrong with it. Shawn |
| vista home basic x32 | Re: Control Panel Desktop Icon thankyou. heres my screen |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Control Panel Desktop Icon Your welcome Ktrentra, Right click on the wrench.ico file and click on Properties. Under the General tab, see if there is a Unblock button. If there is click on it to unblock the file. If not, then it's already unblocked. Next, try these value combinations to see if they will work for you instead: %USERPROFILE%\Downloads\icons\wrench.ico OR "C:\Users\Kyle\Downloads\icons\wrench.ico" OR C:\Users\Kyle\Downloads\icons\wrench.ico |
| vista home basic x32 | Re: Control Panel Desktop Icon Nope, none of those worked. Would there be a reason why changing the registry value wouldn't affect it at all? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Control Panel Desktop Icon Ktrenta, Did you refresh the window to see the changes? If so, then try logging off and on to see that helps. You may also have a incorrect icon file. The one in the ZIP file I posted still works fine for me. You might try it or another one as a test to see. |
| vista home basic x32 | Re: Control Panel Desktop Icon nope. it still refuses to change. thank you for your patience |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Control Panel Desktop Icon Ktrenta, I'm not certain why it would not work for you. I have drawn a blank. |
| Vista Home Premium 32bit | Re: Control Panel Desktop Icon Ktrenta, I think the problem is that you are using the 32bit Home Edition while Brink is using the 64bit premium edition. I have the 32bit Edition and have changed my Control Panel icon by changing some different registry keys. To change the icon on the desktop, address bar, and folder trees go to: HKEY_CLASSES_ROOT\CLSID\ {26EE0668-A00A-44D7-9371-BEB064C98683}\DefaultIcon In the right panel, right-click "(Default)" and then "Modify". Change the info the the new icon location. This will not change the control panel icon everywhere. When you click on the star menu and let your pointer rest over where it says "Control Panel", the icon will still be the old icon. To change this one go to: HKEY_CLASSES_ROOT\CLSID\ { 5399E694-6CE5-4D6C-8FCE-1D8870FDCBA0}\DefaultIcon Use same instructions above to change icon. Hope this helps. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Control Panel Desktop Icon Hello CrimsonPhoenix, and welcome to Vista Forums. Thank you for your addition. I hope that it helps Ktrenta as well. The location below used in the tutorial would be there by default in both the 32-bit and 64-bit Vista. It's only for the Desktop and Navigation Pane though. HKEY_CLASSES_ROOT\CLSID\{21EC2020-3AEA-1069-A2DD-08002B30309D}\DefaultIcon |
| Tutorial Tools | |
| Tutorial | Category | |||
| New Control Panel Icon | Vista hardware & devices | |||
| No Mail Icon in the control panel | Microsoft Office | |||
| Control Panel - Hide Icon | Tutorials | |||
| Control Panel Icon on Desktop | Vista General | |||
| Cant delete Control Panel Desktop Icon on Taskbar | Vista General | |||
