Windows Sidebar will not Start in Vista
How to Fix Windows Sidebar not Starting in Vista
This will show you how to get Windows Sidebar to start again if it will not start for you.
STEP ONE
Double Checking
1. See if you have a sidebar.exe listed in Task Manager.​
A) If you do, then End Process it.​
NOTE: This will close the Windows Sidebar exe so hopefully you will be able to open another one if it was just not responding before.​
B) Try doing step 3 now.​
2. Make sure Windows Sidebar is Enabled.​
3. Make sure Windows Sidebar is Turned On.​
4. Check your Firewall or other Security programs to make sure that Windows Sidebar or sidebar.exe is not being blocked.​
5. If Windows Sidebar will not start after this, then proceed to STEP TWO.​
STEP TWO
Fix it Through a Elevated Command Prompt
I would recommend to use Copy and Paste to make doing this easier.
Special thanks to meche94.
2. In the elevated command prompt, type: (See screenshot below)​
A) For 32 bit and 64 bit Vista:
Regsvr32 -u "%ProgramFiles%\Windows Sidebar\sbdrop.dll"
B) Also Type for 64 bit Vista Only:
Regsvr32 -u "%ProgramFiles(x86)%\Windows Sidebar\sbdrop.dll"
C) Press Enter after A and/or B.​
3. Click on OK. (See screenshot below)​
4. In the elevated command prompt, type: (See screenshot below)​
Regsvr32 -u "%ProgramFiles%\Windows Sidebar\wlsrvc.dll"
Regsvr32 -u "%ProgramFiles(x86)%\Windows Sidebar\wlsrvc.dll"
5. Click on OK. (See screenshot below)​
6. In the elevated command prompt, type Regsvr32 atl.dll and press Enter. (See screenshot below)​
7. Click on OK. (See screeshot below)​
8. In the elevated command prompt, type: (See screenshot below)​
Regsvr32 "%ProgramFiles%\Windows Sidebar\sbdrop.dll"
Regsvr32 "%ProgramFiles(x86)%\Windows Sidebar\sbdrop.dll"
9. Click on OK. (See screenshot below)​
10. In the elevated command prompt, type: (See screenshot below)​
Regsvr32 "%ProgramFiles%\Windows Sidebar\wlsrvc.dll"
B) Also type for 64 bit Vista Only:
Regsvr32 "%ProgramFiles(x86)%\Windows Sidebar\wlsrvc.dll"
11. Click on OK. (See screenshot below)​
12. Close the elevated command prompt.​
13. Restart the computer.​
14. Now turn on Windows Sidebar to see if it will start up for you.​
15. Your done. Windows Sidebar should start now.​
NOTE: If Windows Sidebar still does not start, then run a sfc/ scannow command to see if it can find and fix any bad system files that may be the cause.
Re: Windows add gadget button in sidebar doesnt work :(
Hi shawn :)
thanks for your post..:) hope you can help me...:(
my problem is this:
when i try the "add gadget" the window that is supposed to pop up in the screen doesnt pop up, when i try clicking the ( + ) icon in the sidebar, to launch the screen it doesnt work either.
basically, evreything works. but the "add gadgets- window" doesnt pop up, thus i cant customize my installed gadgets. pretty much stuck with my current gadget that is in my sidebar.
Is there a way i can re-install windows sidebar in my laptop w/o installing windows vista again?
Im using WINDOWS vista home premuim 32 bit.
recently bought laptop VAIO 1/17/08
pls help
:o
- valerie
Hi Valerie,
Have you already tried STEP TWO above to see if it will reset Windows Sidebar for you?
If so, then you can try running a sfc /scannow command to see if it can find a problem with a system file and fix it.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
If that still does not help, then you can run a Repair install. This will allow you to repair your Vista installation and keep your user account files, settings, and programs.
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
hi :)
thanks for the post. i did the sfc /scannow
the command promted could be summariezed: 99% complete, done but with some errors could not fix
:( i dont want to do the repair install because as of the moment,
the drivers of the laptop arent with me and if something went wrong i dont have any computer to use and my work involves computer work as i am in web and graphic design field.
:( huhuh pls help..any more ideaS?:o
Went the cmd route and solved the prob. Thx Brink for the concise tut ;-) Searched MS for solution w/o success...googled and got u. Thanks again :-)
Your welcome ajbuzzy, and welcome to Vista x64 Forums. :party:
I've got problem with my sidebar. One day when i switch on my computer and the windows vista started i saw that something is wrong with my sidebar: in sidebar showed up about 50the same gadgets. When i try to delete one of this gadgets the computer stop and nothing gonna work
Hi PonuryUser,
See if you can boot into Safe Mode and do Step Two to see if that will help you.
PonuryUser,
You can open the Start menu and right click on the Computer button, on the dark right side, and click Properties. You will see if you have the 32 bit or 64 bit version under the Sytem section to be sure.
It's ok if you typed the 64 bit only part in by mistake. That part will just not do anything on a 32 bit Vista. That's all.
Hi PonuryUser,
That's ok. This works on both the 32 bit and 64 bit Vista versions. Towards the upper right corner of every tutorial you will see a Applies to box that will let you know what versions of Vista it will work for.
Your welcome DippyDawg, and welcome to Vista Forums. :party:
I''m glad to hear that you have it working again. Step Two unregisters and then re-registers the .dll files responsible for running Windows Sidebar. It basically resets them.
Greetings :cool:
I have a problem with the Vista Sidebar after delete programme (Kaspersky Internet Security 7):mad:
Sidebar has become such well
Please help .. :rolleyes:
Hi Azrk7,
You might need try uninstalling and reinstalling those gadgets to see of that will allow them to run properly. If not, then turn Windows Sidebar off and try Step Two in this tutorial to see if it can help.
Hi Brink
I got tools from the site and proved Microsoft
The same problem
Purple find a solution
Sidebar possible programme or update him
Azrk7,
Were you able to fix it? Step Two in this tutorial is listed in other sites as a fix for this problem also.
THANKS SO MUCH MAN! I really appreciate your help I just did this tutorial and now my sidebar works.. and I had tried quite a few things before this.
Thanks Again,
Andrew
    AMD Athlon 64 X2 5600+ 2.8GHz
    Asus M2N68-LA
    3.00 GB
    Nvidia GeForce 8600 GTS
    400GB SATA
    Saitek Cyborg Keyboard
