Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Vista - How to fax without a fax machine in vista
Comment
How to Fax without a Fax Machine in Vista
got scanner ? got printer ? but no fax machine !
Published by NicksonBlue
01-04-2008
Post How to Fax without a Fax Machine in Vista
If you have a scanner, a printer, but have no fax machine! for sure... you have to plug your fax line to your computer (line card needed), if your fax line is plugged on other computer, you can connect to a fax server on your network (make sure you know the server name)
_______________________________________
1) Go to start, type in windows fax in the search bar, then select <Windows Fax and Scan>
2) Click <New Fax>, Choose your fax modem or server,
a) If you have a modem that is built in or connected to your computer , Click <Connect to a fax modem> and type in a name you want for your fax (any name).
b) If your computer connects to a fax server on your network, click <Connect to a fax server on my network> and type in your server name.
3) Then choose which way you want to receive faxes
a) If You want to receive faxes automatically, choose <Answer automatically> (don't worry you will never receive viruses)
b) If you want to receive faxes manually, choose <Notify me> (answer automatically is recommended)
c) If you are not sure ,then choose later (you have to change the setting manually after or later)
4) Done! You can now create a new fax!
(To delete the fax account, click <Tools>, select <Fax accounts>, press <remove>)
Published by
NicksonBlue's Avatar
Pro
NicksonBlue is on a distinguished road
Tutorial Tools
Applies to
Business,Enterprise,Ultimate
64 Bit & 32 Bit
09-18-2009
pacinitaly
VISTA Business 32bit SP2
worst state in America
Re: How to fax without a fax machine in vista
is this for business or ultimate?
Comment
How to fax without a fax machine in vista problems?
Tutorial Tools
Similar topics to: How to fax without a fax machine in vista
Tutorial Category
Vista Machine unable to print to Printer attached to 98 machine thru parallel port Network & Sharing
Connecting a Vista machine to a printer shared on an XP machine. Vista print fax & scan
Booting my XP machine from a mapped drive on my vista machine Vista networking & sharing
Importing Outlook 2003 Contacts and Mail from an XP machine to a new Vista machine Vista mail
Re: Vista machine cause XP machine to lose inet access Vista networking & sharing
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
