Reduced Functionality Mode
  1. #61
    Brink's Avatar
    Administrator
    Texas, USA
    64-bit Vista Ultimate SP2, Windows 7 Ultimate SP1, Windows 8 Enterprise
    Local Time: 05:25 PM
    usa us texas
      Thread Starter
    How to Get Out of Reduced Functionality Mode in Vista
  2. #60
    NoelDP's Avatar
    Three-Toed Sloth
    Wales - usually in the pub :)
    Vista HP 32-bit (also 64-bit VM)
    Local Time: 11:25 PM
    uk uk wales
    Re: Reduced Functionality Mode
    At the moment, I'm more concerned with trying to get the whole OS into a usable state fit for activation than anything else
    It *may* activate as it is, but later action may break it again, and then cause problems
  3. #61
    Junior Member
    Windows Vista Home Premium
    Local Time: 06:25 AM
    Quote Originally Posted by townsbg View Post
    See step 2 for phone activation. Activate Vista by Phone
    Also try extending activation: Activation - Extend Trial Period
    Phone activation will not work for me because mine windows is an OEM version, plus I couldn't find any phone activation option anywhere.
    Quote Originally Posted by NoelDP View Post
    Let me rephase things in an effort to make it clear.
    When you use the Recovery Environment, the C: drive is almost never the same one as the original C:drive.
    The X: drive is the one that is currently in use by the Recovery Environment as it's working system drive - and the system re-orders the drives into the order in which they are on the hard disk. Almost always, the first partition is either the Reserved (Boot) partition, or the manufacturer's Recovery partition, and this may or may not have a Windows folder, but will be called C:
    the next partition is usually what would normally be called the System drive C: drive - and the drive letter has changed to D:
    If for whatever reason, there is another partition prior to the System one, then the System drive will become E:
    That's as far as most systems can go because of a limit of 4 primary partitions to any drive, but it is actually possible to have many more drive-letters prior to the System drive you need to access.
    Once you boot back into Windows proper, the drive letter assignments go back to normal (unless you've done somehting to them while in the recovery environment.)
    Quote Originally Posted by noelcwt View Post
    My windows file is located in c:\ but the command prompt shows something like x:\windows\system32 so I tried both. I did keyed in the correct command without <>, but it just won't work. See screenshot 2 and 3.
    That's the point I'm trying to make - as far as I can see, you never used the D:\....
    option.
    PLease try it again.
    Hi, in fact I've already tried partition c:\ d:\ and x:\, the windows file is showing it's in c:\ partition during repair mode, not d:\, I also tried x:\ just in case but it's not working. As it is now, I have only two options left, to recover to factory setting every now and then (around 3 days) or send it to acer and pay for the activation which I don't think it's worth while .
  4. #62
    townsbg's Avatar
    ~~тσωηsвg~~
    US of A
    Mac OS X 10.8
    usa
    You have to pay Acer for activation?
  5. #63
    Junior Member
    No, but I have to pay a handling charges of 50 bucks if I were to bring my laptop in, service or not, they will charge first before they even take a look on it as the warranty period of my laptop have expired long time ago.
    As I replied, I have just restore my laptop to factory default settings cause I couldn't start my windows after I tried this from the earlier reply.
    Sorry - I was obviously even later to the party than I thought
    Try this - the Licensing Store may be corrupt.
    Recreate the Licensing Store with the correct data.
    1) Open an Internet Browser window.
    2) Type: %windir%\system32 into the browser address bar.
    3) Find the file CMD.exe
    4) Right-Click on CMD.exe and select 'Run as Administrator'
    5) Type: net stop slsvc (it may ask you if you are sure, select yes)
    6) Type: cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing
    7) Type: rename tokens.dat tokens.bar
    8) Type: cd %windir%\system32
    9) Type: net start slsvc
    10) Type: cscript slmgr.vbs -rilc (It may take a long time for this to complete, please be patient)
    11) Restart your computer twice.
    You may be asked to enter your COA Key and/or Activate. – if asked for the Key, use the one on your COA sticker on the machine’s case (you may need to activate by telephone).
    Once complete, run another MGADiag report and post back with the results.
  6. #64
    NoelDP's Avatar
    Three-Toed Sloth
    uk uk wales
    Noel
    Please post anew MGADiag report, and define your current problems if any - I'm getting confused (not too unusual)
  7. #65
    Junior Member
    Code:
    Diagnostic Report (1.9.0027.0):
    Windows Validation Data-->
    Validation Status: Genuine
    Validation Code: 0
    Cached Online Validation Code: N/A, hr = 0xc004f012
    Windows Product Key: *****-*****-XY9X3-JDXYP-6CJ97
    Windows Product Key Hash: xFQJU8srKsovk6p1Lk1yW93in4E=
    Windows Product ID: 89578-OEM-7332157-00211
    Windows Product ID Type: 2
    Windows License Type: OEM SLP
    Windows OS version: 6.0.6000.2.00010300.0.0.003
    Is Admin: Yes
    TestCab: 0x0
    LegitcheckControl ActiveX: N/A, hr = 0x80070002
    Signed By: N/A, hr = 0x80070002
    Product Name: Windows Vista (TM) Home Premium
    Architecture: 0x00000000
    Build lab: 6000.vista_rtm.061101-2205
    TTS Error:
    Validation Diagnostic:
    Resolution Status: N/A
    Vista WgaER Data-->
    ThreatID(s): N/A, hr = 0x80070002
    Version: N/A, hr = 0x80070002
    Windows XP Notifications Data-->
    Cached Result: N/A, hr = 0x80070002
    File Exists: No
    WgaTray.exe Signed By: N/A, hr = 0x80070002
    WgaLogon.dll Signed By: N/A, hr = 0x80070002
    OGA Notifications Data-->
    OGAExec.exe Signed By: N/A, hr = 0x80070002
    OGAAddin.dll Signed By: N/A, hr = 0x80070002
    OGA Data-->
    Office Status: 102
    Microsoft Office Home and Student 2007 - 100 Genuine
    OGA Version: N/A, 0x80070002
    Office Diagnostics: 77F760FE-153-80070002_7E90FEE8-175-80070002_025D1FF3-364-80041010_025D1FF3-229-80041010_025D1FF3-230-1_025D1FF3-517-80040154_025D1FF3-237-80040154_025D1FF3-238-2_025D1FF3-244-80070002_025D1FF3-258-3_B4D0AA8B-920-80070057
    Browser Data-->
    Proxy settings: N/A
    User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Win32)
    Default Browser: C:\Program Files\Mozilla Firefox\firefox.exe
    Download signed ActiveX controls: Prompt
    Download unsigned ActiveX controls: Disabled
    Run ActiveX controls and plug-ins: Allowed
    Initialize and script ActiveX controls not marked as safe: Disabled
    Allow scripting of Internet Explorer Webbrowser control: Disabled
    Active scripting: Allowed
    Script ActiveX controls marked as safe for scripting: Allowed
    File Scan Data-->
    Other data-->
    Office Details: <GenuineResults><MachineData><UGUID>{7FDFB795-2FEF-4807-965C-9E11AA5CD702}</UGUID><Version>1.9.0027.0</Version><OS>6.0.6000.2.00010300.0.0.003</OS><Architecture>x32</Architecture><PKey>*****-*****-*****-*****-6CJ97</PKey><PID>89578-OEM-7332157-00211</PID><PIDType>2</PIDType><SID>S-1-5-21-3351150264-1421152639-2744056330</SID><SYSTEM><Manufacturer>Acer           </Manufacturer><Model>Aspire 4710                    </Model></SYSTEM><BIOS><Manufacturer>Phoenix Technologies LTD</Manufacturer><Version>V1.18          </Version><SMBIOSVersion major="2" minor="4"/><Date>20080221000000.000000+000</Date></BIOS><HWID>E5313507018400FA</HWID><UserLCID>4409</UserLCID><SystemLCID>0409</SystemLCID><TimeZone>Malay Peninsula Standard Time(GMT+08:00)</TimeZone><iJoin>0</iJoin><SBID><stat>3</stat><msppid></msppid><name></name><model></model></SBID><OEM><OEMID>ACRSYS</OEMID><OEMTableID>ACRPRDCT</OEMTableID></OEM><GANotification/></MachineData><Software><Office><Result>102</Result><Products><Product GUID="{91120000-002F-0000-0000-0000000FF1CE}"><LegitResult>100</LegitResult><Name>Microsoft Office Home and Student 2007</Name><Ver>12</Ver><PidType>19</PidType></Product></Products><Applications><App Id="16" Version="12" Result="100"/><App Id="18" Version="12" Result="100"/><App Id="1B" Version="12" Result="100"/><App Id="A1" Version="12" Result="100"/></Applications></Office></Software></GenuineResults>
    Spsys.log Content: 0x80070002
    Licensing Data-->
    Software licensing service version: 6.0.6000.16509
    Name: Windows(TM) Vista, HomePremium edition
    Description: Windows Operating System - Vista, OEM_SLP channel
    Activation ID: bffdc375-bbd5-499d-8ef1-4f37b61c895f
    Application ID: 55c92734-d682-4d71-983e-d6ec3f16059f
    Extended PID: 89578-00146-321-500211-02-1033-6000.0000-1632012
    Installation ID: 176081461474865730922665843100253585826030314210614053
    Processor Certificate URL: http://go.microsoft.com/fwlink/?LinkId=57201
    Machine Certificate URL: http://go.microsoft.com/fwlink/?LinkId=57203
    Use License URL: http://go.microsoft.com/fwlink/?LinkId=57205
    Product Key Certificate URL: http://go.microsoft.com/fwlink/?LinkId=57204
    Partial Product Key: 6CJ97
    License Status: Initial grace period
    Time remaining: 20177 minute(s) (14 day(s))
    Windows Activation Technologies-->
    N/A
    HWID Data-->
    HWID Hash Current: OAAAAAIAAwABAAEAAwABAAAAAgABAAEAeqi4mXcWZNDkTPwfSOQqhg4kBPwIavL0ZHJOGaxWKoU=
    OEM Activation 1.0 Data-->
    N/A
    OEM Activation 2.0 Data-->
    BIOS valid for OA 2.0: yes, but no Windows marker
    Windows marker version: N/A
    OEMID and OEMTableID Consistent: yes
    BIOS Information:
      ACPI Table Name    OEMID Value    OEMTableID Value
      APIC            INTEL         CALISTGA
      FACP            INTEL         CALISTGA
      HPET            INTEL         CALISTGA
      BOOT            PTLTD         $SBFTBL$
      MCFG            INTEL         CALISTGA
      TCPA            PTLTD         CALISTGA
      SLIC            ACRSYS        ACRPRDCT
      APIC            INTEL         CALISTGA
      SSDT            SataRe        SataAhci
    The SFC scan will not complete either in windows cmd or repair mode cmd. That is the same error I got everytime (if I am able to get an SFC scan done)
  8. #66
    NoelDP's Avatar
    Three-Toed Sloth
    uk uk wales
    please boot to the Recovery mode command prompt, and run the following command
    DISKPART
    once the new prompt comes up, enter
    List Volume
    Make a note of ALL the volumes listed and their letters and other details
    type EXIT twice, and reboot.
    post the results
  9. #67
    Junior Member
    Here's the result
  10. #68
    NoelDP's Avatar
    Three-Toed Sloth
    uk uk wales
    Very odd!
    C: ACER (NTFS)
    D: ACERDATA (FAT32)
    E: DVDROM
    F: My Passport (NTFS)
    X: PQSERVICE (FAT32)
    The only two partitions which are capable of holding a Win7 system are C: and F: - F: is presumably an external drive?
    The C: and D: and X: drives together only come to 149GB (with overhead, perhaps a 160GB drive?)
    Please disconnect the external drive while attempting to troubleshoot - it may be introducing factors which complicate matters.
    In BOTH the pictures in your earlier post the source drive is C:.
    It should not be so, from a Recovery boot - it would normally be X:.
    Please reboot to the Recovery console again, and access the Command Prompt option
    DO NOT change anything, but sinply check the window header - what exactly does it say?
    Now use the following command
    SFC /SCANNOW /OFFBOOTDIR=C:\ /OFFWINDIR=C:\WINDOWS
    what happens??
    - remember that it will take some time to complete, so be patient!
Page 7 of 7 FirstFirst ... 567
Reduced Functionality Mode problems?
Tutorial Tutorial Starter Category Comments Last Post
Reduced Functionality mode Woodishi Vista General 5 03 May 2007
Recovering from reduced functionality mode Woodishi Vista installation & setup 1 03 May 2007
Windows runs in Reduced Functionality mode after activation... iLLz Vista installation & setup 12 13 Apr 2007
How do I access the command prompt in reduced functionality mode? Dirkpitt Vista account administration 4 16 Mar 2007
Vista entering reduced functionality mode without warning Shelby Cain Vista installation & setup 12 04 Mar 2007
