Vista Forums
Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Vista Tutorial Categories Network & Internet Tutorials File & Folder Settings Tutorials Taskbar & Start Menu Tutorials Performance & Maintenance Tutorials General Tips Tutorials Programs & Features Tutorials Context Menu Tutorials Shortcut Tutorials Security & System Tools Tutorials Parental Controls Tutorials User Account Tutorials Hardware & Drivers Tutorials Appearance & Personalization Tutorials Backup & Restore Tutorials Music, Photo, Video and Media Tutorials Power Management Tutorials
Previous Versions - Shadow Copy
Update your Vista Drivers Update Your Drivers Now!!
Poll: Did this Tutorial help and work for you?
Poll Options
Comment
Tutorial Tools Display Modes
<!-- google_ad_section_start -->Previous Versions - Shadow Copy<!-- google_ad_section_end -->
How to Restore Previous Versions of a File and Folder in Vista
Published by Brink
01-17-2008
Information
  This will show you how to restore Previous Versions of a file or folder from a list of previous versions (shadow copy) at different points in time to choose from. Shadow copies are automatically saved as part of a system restore point. When System Restore is turned on (it is by default), Vista automatically creates shadow copies of any files that have been changed since the time the last restore point was made. Restore points are created once per day and before significant system events such as program or driver installation. You can also manually create a restore point anytime you want to. For more information, see: Microsoft TechNet: Selected Scenarios for Maintaining Data Integrity with Windows Vista
NOTE
  This is only available for the Ultimate, Business, and Enterprise editions of Windows Vista. For the other Vista editions, you might try this free alternative: http://www.shadowexplorer.com/
Tip
WARNING
  System Restore must be turned on for this to work.
Select the drive you want System Restore to use for the storage of restore points. For how, see: How to Disable or Enable System Restore in Vista
REQUIRED SERVICES:
For how to change, see: How to Disable or Enable Vista Services With a Advice Guide
  • Volume Shadow Copy - Default setting is Started and Manual.
  • Server - Default setting is Started and Automatic.
  • TCP/IP NetBios Helper - Default setting is Started and Automatic.
  • Workstation - Default setting is Started and Automatic.
RELATED LINKS:
EXAMPLE: Previous Versions window
1. For a Current File or Folder -
NOTE: To restore a previous version of a file or folder that a is still located in it's location. Not deleted.
A) Right click on the file or folder.
B) Click on either Properties or Restore previous versions. (See screenshot below)
C) Go to step 3.
2. For a Deleted File or Folder -
NOTE: This is for a file or folder that is no longer in the folder where it was originally located. You will need to do this in the folder that the file or folder was originally located to restore it.
A) Right click on a empty area in a Windows Explorer window for the original folder location. (See screenshot below)
OR
B) Right click on the folder in the Windows Explorer Navigation Pane.
C) Click on Properties.
3. Click on the Previous Versions tab. (See screenshots below)
NOTE: All files and folders will have a activated Restore button option except for the ones in C:\Windows.
4. Select a previous version date that you want to restore by letting your pointer hover over it until it is highlighted.
Size:  116.9 KBName:  Previous_Versions_Properties.jpg
5. To View the File or Folder Previous Versions -
NOTE: This will open a separate window where you can view the contents of the selected previous version.
A) Click on the Open button, or on one of the dated previous versions. (See screenshots above)
6. To Copy the File or Folder Previous Version to a Selected Location -
NOTE: You can use this to copy a previous version to another location or the same location to replace the original. For example, the C:\Windows location since it does not have a activated Restore button.
A) Click on the Copy button. (See screenshots below step 4)
B) Navigate to the location you want to place the copy of the previous version of the file or folder. (See screenshot below)
NOTE: If you would like to create a new folder to put the previous version in at that location first, then click the Make New Folder button and type a name for it.
C) Click the Copy button.
D) If there is a current copy of the file or folder in that same location, then click on the option you want to do. (See screenshot below)
7. To Restore the File or Folder Previous Version -
NOTE: This will replace the current file or folder with the selected previous version.
A) Click on the Restore button. (See screenshots below step 4)
NOTE: The Restore button is grayed out for files and folders in the C:\Windows location.
B) Click on the Restore button. (See screenshot below)
C) Click OK. (See screenshot below)
Published by
Brink's Avatar
Administrator
Brink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond repute
Tutorial Tools
Show Printable Version Show Printable Version
Email this Page Email this Page
Applies to
Business,Enterprise,Ultimate
64 Bit & 32 Bit
Old 04-19-2008
vaderag
Newbie
Vista Ultimate 64
vaderag is on a distinguished road
  vaderag is offline
Re: Previous Versions - Shadow Copy
Is there any way to hide the Restore Previous Versions from the context menu?
Old 07-24-2008
tigpoppa
Newbie
vista 32
tigpoppa is on a distinguished road
  tigpoppa is offline
i agree how do i get rid of this in the context menu!!!!!
THANK YOU
Old 07-24-2008
Brink's Avatar
Brink
Administrator
Vista x64 Ultimate SP1
Texas, USA
  Brink is online now
Hi Tigpoppa and Vaderag,
This tutorial fresh out of the oven will show you how to.
Restore Previous Versions - Restore or Remove from Context Menu
You might also be interested in this one to:
Previous Versions Tab - Restore or Remove from Properties
Old 07-27-2008
tigpoppa
Newbie
vista 32
  tigpoppa is offline
Quote:
Brink
View Post
awesomes finally someone figured it out!
gold stars all around!
Old 07-27-2008
Brink's Avatar
Brink
Administrator
Texas, USA
  Brink is online now
LOL, your welcome Tigpoppa.
Old 3 Weeks Ago
minorgeek
Newbie
Vista Home Premium 32bit
minorgeek is on a distinguished road
  minorgeek is offline
Red face Re: Previous Versions - Shadow Copy
i'm confused. i thought system restore saved only system files (registry, i'd guess, and few more). this article seems to say it saves ALL (changed) files. i have home premium. is that still true? can i keep system restore functionality and tell it not to save all my other files? must take humongus amount of space and i back up daily and i can't access those older versions in shadowcopies, so it just wastes space.
thanks!
Old 3 Weeks Ago
Brink's Avatar
Brink
Administrator
Texas, USA
  Brink is online now
Hello MinorGeek, and welcome to Vista Forums.
Since you have Vista Home Premium, the Previous Versions feature is not available for your edition. However, you can use the free program mentioned in the Note box at the top of the tutorial to be able to take advantage of and use shadow copy for previous versions of your files.
Previous Versions is handled by Shadow Copy which is not the same as System Restore and restore points. However, they do work very closely together. See the link in the Information box at the top of the tutorial for a more detailed explanation of Previous Versions.
Old 3 Weeks Ago
.Joe's Avatar
.Joe
1337 spammer
Vista x86 Ultimate SP1
127.0.0.1
.Joe has much to be proud of.Joe has much to be proud of.Joe has much to be proud of.Joe has much to be proud of.Joe has much to be proud of.Joe has much to be proud of.Joe has much to be proud of.Joe has much to be proud of
  .Joe is offline
Another excellent tutorial Shawn!
Old 3 Weeks Ago
Brink's Avatar
Brink
Administrator
Texas, USA
  Brink is online now
Your welcome Joe, and thank you.
Comment
Tags
backup & restore, previous
Tutorial Tools
Display Modes
Tutorial Tutorial Starter Category Comments Last Post
help shadow copy and previous version not working. GT Vista General 1 04-14-2008 07:25 PM
Folder Versions has Non Existent List in Previous Versions Tab Sid Vista performance & maintenance 1 02-12-2008 01:55 AM
Shadow Copies (Previous versions) of files do not work? Alexander Vista General 2 07-06-2007 05:02 PM
shadow copy (previous version) Jeff Vista General 6 01-24-2007 10:49 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
