Vista - System Restore Points - Stop XP Dual Boot Delete
Comment
Old 02-06-2008
Brink
How to Stop System Restore Points from being Deleted in Vista when Dual Booting with XP
Old 08-20-2008
Brink
Re: System Restore Points - Stop XP Dual Boot Delete
No problem Steve, that's how I learned everything on the computer. (See Signature )
Yeah, the limit is 4 partitions per drive though.
Old 08-21-2008
stox
Vista Home Premium 64bit SP1
Ok, thanx for that..
Althougth that has got me thinking... i already have 4 partitions on 1 drive. 3 are primary and 1 is logical.
I'm presuming that that is the limitation, or could i have 4 primary's ?
Old 08-21-2008
Brink
It's just a 4 partitions limit of any kind with Disk Management.
Old 08-21-2008
stox
Okies. But is it possible to have 4 primary partitions ?
I know you can have 3 primary partitions in Vista... well thats what mine did originally.
Old 08-21-2008
Brink
Stox,
Yes you can have up to 4 primary partitions per actual hard drive.
See the information box at the top of this tutorial below for more on this. You might be able to setup an extended partition to work around the 4 partition limit using the Microsoft link provided in the table. I have not tried this myself, so I do not know how it will work though.
Disk Management - Shrink Partition
Old 08-22-2008
stox
okies...
Old 11-16-2008
Larvald
Vista Home Basic 64-bit EN
If you have Vista on your C: drive and XP installed on another drive eg. D: this "hiding C:" workaround disables you from installing Adobe Flash Player plug-in on XP. For some reason Flash Player plug-in installation requires C: drive available during installation.
ref. http://kb.adobe.com/selfservice/view...6903&sliceId=1
Error: "You do not have sufficient disk space to complete this installation" when installing Flash Player 10 on Windows
The Adobe FP workaround is not feasible, as renaming C: in order to name another drive C: is not possible.
You Have to undo the "dual boot workaround" then loosing your Vista restore points.
Old 11-16-2008
Brink
Hello Larvald, and welcome to Vista Forums.
After you have undone the "dual boot workaround" and installed the Flash Player, were you able to enable the "dual boot workaround" again without any problems with the Flash Player?
You might try the Adobe Flash Player direct download link to see it will work better for you.
Old 11-17-2008
Larvald
Hi Shawn!
Thank you, nice to get a rapid reply!
There was no problem introducing the "dual boot workaround" after the Firefox Flash Player plugins were successfully installed and FP and the "dual boot workaround" works just ok.
The "direct download" install ok even with the "dual boot workaround" activated.
As the Adobe workarund mention installing ActiveX control has not this problem like the plug-in has. Does the "direct download" also install the plug-in?
I was in contact with the Adobe support-portal in my trials to get a solution to my problem. They finally concluded that I had some strange configuration they don't support and thus could not help me. Then I remembered that I long ago did introduce the "dual boot workaround" and jess...
What amazes me is, that am I the only one with a Vista/XP dualboot with Vista on C:? Are there other applications with this C: drive need?
Lars
Old 11-17-2008
Brink
You're welcome Lars,
The direct download installs the Adobe Flash Player IE add-on.
Comment
Tutorial Tools
Tutorial Category
Solved Can't Delete System Restore Points General Discussion
Dual Boot Vista - XP backup restore losing restore points Vista General
dual boot xp and restore points in vista Vista General
Dual boot and Vista restore points Vista General
System Restore Points in a dual boot enviroment Vista General
