| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | System Restore Points - Stop XP Dual Boot Delete How to Stop System Restore Points from being Deleted in Vista when Dual Booting with XP Last edited by Brink; 04-28-2009 at 04:09 PM.. |
| Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro | Re: System Restore Points - Stop XP Dual Boot Delete Hello Brink. I just used option 2 in this excellent tutorial to get XP to stop eating the Vista restore points; it worked like a charm. Thanks Shawn!... ![]() Later Ted |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Points - Stop XP Dual Boot Delete You're welcome Ted. |
| Windows Vista Ultimate x86 SP1 | Re: System Restore Points - Stop XP Dual Boot Delete Hey there.. Firstly, i wanna thank you so so very much Brink for this particular tutorial. I've been using Vista for a few months now and everytime i did/installed something bad, i tried to do a system restore but Vista prompt that i don't have any. So i thought i had it turned off and checked. It's turned on but restore points just keeps disappearing. I'm on XP and Vista Dual-boot. XP on C: and Vista on F: ( same drive ). Did some research on Google and was linked to this site. I did exactly how you explained it and it worked ! I tried Option 2 btw. Again, i wanna thank you so much. Have a great day ! Danny |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Points - Stop XP Dual Boot Delete You're welcome Danny. I'm happy to hear that you got it sorted out. Shawn |
| Vista Ultimate x64 | Re: System Restore Points - Stop XP Dual Boot Delete I've a question: if I work on Windows Vista it says me that Vista is on C: and XP is on D: but if I work on XP it saus me that XP is on C: and Vista is on D: Now which letter do I use in the regeditor? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Points - Stop XP Dual Boot Delete Hello Angyecarm, While doing this tutorial in XP, you would use the D: drive letter for Vista then. ![]() Shawn |
| Vista Ultimate x64 | Re: System Restore Points - Stop XP Dual Boot Delete Thanks! So how can I try if it's work? This tutorial help me also with Shadow Copy? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Points - Stop XP Dual Boot Delete Yep, once this is applied, it should allow Vista to start keeping all of it's restore points and shadow copies for you to use Previous Versions. |
| Vista Ultimate x64 | Re: System Restore Points - Stop XP Dual Boot Delete Ok! So if a restart my PC and try to do a restore it must be work? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: System Restore Points - Stop XP Dual Boot Delete No, not yet. Vista will not have any restore points or Previous Versions yet since it is just now starting to store them. You or Vista will need to create restore points first before you can do that after applying this tutorial. |
| Tutorial Tools | |
| Tutorial | Category | |||
Can't Delete System Restore Points | General Discussion | |||
| Dual Boot Vista - XP backup restore losing restore points | Vista General | |||
| dual boot xp and restore points in vista | Vista General | |||
| Dual boot and Vista restore points | Vista General | |||
| System Restore Points in a dual boot enviroment | Vista General | |||
