1.    05 Apr 2012 #300
    Texas, USA
    64-bit Windows 10 Pro
    Local Time: 10:58
    usa us oklahoma
      Thread Starter
    Re: Create a Recovery Disc
    It works the same in both Vista and Windows 7. The files needed are within the system cab files that are included in Vista and Windows 7 when installed. I can't remember the exact location of them though.
    I'd be interested in your findings if you give it a play.
  2.    05 Apr 2012 #301
    VISTA HOME PREMIUM X64/ 7 x64 / 7x86
    Local Time: 16:58
    I might try putting my own winre.wim on the Vista partition and add it as a boot option.
    Then maybe the Beta Vista recdisc.exe will pick it up.
  3.    05 Apr 2012 #302
    Local Time: 16:58
    Wow - forgot how fast Vista boots - amazing.
    Afraid you still need the Vista install dvd to make a recovery disc.
    -vista-recdisc-beta-jpg
    -vista-recdisc-beta2-jpg
  4.    05 Apr 2012 #303
    Texas, USA
    Local Time: 10:58
    usa us oklahoma
      Thread Starter
    LOL, well you can tell it's been a while since I used Vista. I must have been thinking Windows 7 as you said.
  5.    05 Apr 2012 #304
    Local Time: 16:58
    I had forgotten a lot about it too.
    Fun to have another look at it now.
    You don't know what you are missing.
  6.    22 Apr 2012 #305
    32bit
    Local Time: 11:58
    Why is this better than just using Back up files @ the Vista Backup & Restore Center option?
  7.    22 Apr 2012 #306
    Texas, USA
    Local Time: 10:58
    usa us oklahoma
      Thread Starter
    Hello Brucenpattyann, and welcome to Vista Forums.
    A recovery disc is only a bootable DVD that allows you to use it to boot to the "System Recovery Options" screen. It cannot be compared to what you mentioned since it is not the same. What is better depends on your needs instead.
    Did you have any questions about this to help clear up any confusion that you may have had?
  8.    29 Apr 2012 #307
    Vista Home Premium 32bit SP2
    Local Time: 11:58
    Hey Brink I've got a question for you. My mbr got messed up when I was messing around with some partitions (facepalm). I have a Recovery DVD that was sent with my laptop but for some reason it doesn't give me the option of trying to repair vista and get into the recovery console. It only lets me re-install vista, which i don't want to do. I am able to get back into my Vista desktop by using a PLoP Boot Manager DVD I made prior to the mbr mess-up. I then opened up command prompt and tried running the commands "bootrec.exe /fixmbr" and "bootrec.exe /fixboot" but it doesn't recognize them as commands. I figured it would work just fine through cmd but i guess not. do i need to put something before those commands to make it work or should i just make a recovery disk and do it that way? Thanks for your help!
    Well I figured it'd be nice to have a recovery disk on hand so i just went that route so don't worry about me. thanks for the great walk through!
  9.    29 Apr 2012 #308
    Texas, USA
    Local Time: 10:58
    usa us oklahoma
      Thread Starter
    You're welcome Ralzorf, and welcome to Vista Forums.
    Were you able to get your boot issue sorted?
  10.    30 Apr 2012 #309
    Local Time: 11:58
    yeah my boot issue for vista is sorted now. phew. i was worried for a bit there. haha
Page 31 of 38 FirstFirst ... 212930313233 ... LastLast
Tutorial Category
Create a Gateway OEM Recovery Disc
I recently purchased a Gateway laptop M-6888U that had no software disc provided. I was told by Bestbuy to simply backup my entire drive. I wish to...
General Discussion
Need to create a recovery disc
Hi, recently Vista failed to start on boot-up and I had to do a restore to partition one to get it going. Needless to say this is a lot of work as I...
General Discussion
Create or get OEM Recovery Disc?
I have a question and am in hopes someone has the answer. Ok my Dad has the Vista64 on his Gateway computer. Well he didn't make the disc when he...
General Discussion
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
