Start Menu All Programs List - Enable or Disable
How to Enable or Disable Start Menu "All Programs" in Vista and Windows 7
This will show you how to have the All Programs list added or removed from the Start menu of the user account that this is done in. The All Programs list is enabled by default in Vista and Windows 7.
In Vista, this will only work on the normal Start menu and not the classic Start menu.
EXAMPLE: All Programs List Enabled in the Start Menu
EXAMPLE: All Programs List Disabled in the Start Menu
OPTION ONE
2. In the left pane, click on User Configuration, Administrative Templates, and Start Menu and Taskbar. (See screenshot below)​
3. In the right pane, right click on Remove All Programs list from the Start menu and click on Properties. (See screenshot above)​
4. To Enable All Programs
A) Select (dot) Disabled or Not Configured and click on OK. (See screenshot below)​
B) Go to step 8.​
5. To Disable All Programs
6. Close Local Group Policy Editor window. Your done.​
OPTION TWO
Using a REG File Download
1. To Enable All Programs
Enable_Start_Menu_All_Programs.reg
download
B) Go to step 3.​
2. To Disable All Programs
Disable_Start_Menu_All_Programs.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
7. Log off and log on, or restart the computer to apply.​
OPTION THREE
Manually in Registry Editor
1. Open the Start Menu.​
3. If prompted by UAC, click Continue (Vista) or Yes (Windows 7).​
5. To Disable All Programs in Start Menu
A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (See screenshot above)​
B) Type NoStartMenuMorePrograms and press Enter.​
C) Right click on NoStartMenuMorePrograms and click on Modify. (See screenshot below)​
F) Go to step 7.​
6. To Enable All Programs in Start Menu
A) In the right pane, right click on NoStartMenuMorePrograms and click on Delete. (See screenshot above)​
7. Close regedit.​
8. Log off and log on, or restart the computer to apply.​
  • Enable_Start_Menu_All_Programs.reg
  • Disable_Start_Menu_All_Programs.reg
can you help me pls??? i accidentally deleted all the program list in the start menu (the accessories, games, startup n all those suppose to be in there).. can you help me pls?? how to restore em?
or can you tell me where did the deleted files from recycle bin goes to? im using R-STUDIO
    Dell****
    2.13Ghz Core2Duo
    2GB
    GeForce 9500GT
    Dell****
    Dell****
    1280x960
    Dell****
    Razer Diamondback
    Over 9000 Mbps
Hi Arakai,
You can download the default Start menu shortcuts from this site below and copy them back to your the C:\ProgramData\Microsoft\Windows\Start Menu\Programs folder.
Restore the default Start menu shortcuts
Hope this helps you,
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hey Brink,
When you open the start menu, a list of recently used programs is shown. You can then click on 'All programs' to show the actual menu of your programs. How can I get this menu to be open by default, i.e. I want that when I click the start menu, the menu of programs is shows immediately and not the list of recently used programs.
Thank you,
Laurens,
Hi Laurens, and welcome to Vista Forums.
Sorry, but there is no way to have the Start Menu open with All Programs already opened as far as I know. :(
