Search Start Menu Button - Restore after SP1
How to Restore the Start Menu Search Button after Installing the Vista SP1
When you install the Vista SP1 it will remove the Search button option from the Start menu. This will show you how to restore the Search button on the right dark side of the Start menu after you installed the Vista SP1.
You will be adding Search button back to the right dark side of the Start menu by replacing either the Help and Support button or Run button with Search. If you prefer to not replace either one of these, then you can create a Search shortcut and Pin it to the left side of the Start menu instead. See: How to Create a Search Desktop Shortcut on Vista
EXAMPLE: Search button in the Start Menu Before and After Installing the Vista SP1
EXAMPLE: Search option in the Customize Start Menu window after Vista SP1
NOTE:
The left screenshot is after installing the Vista SP1. The right screenshot is after you replaced either Run command or Help and Support with Search. This will show you how to enter the Customize Start Menu window: How to Customize the Start Menu in Vista
OPTION ONE
Replace Help and Support with Search
1. To Replace Help and Support with Search
Replace_Help_with_Search.reg
download
B) Go to step 3.​
2. To Restore Help and Support
Restore_Help.reg
download
4. Right click on the downloaded .reg file, and click on Merge.​
5. Click on the Run, Continue (UAC), Yes, and then OK when prompted.​
6. Log off and log on, or restart the computer to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
8. Your Start menu will now look like this. (See screenshot below)​
OPTION TWO
Replace Run with Search
1. To Replace Run with Search
Replace_Run_with_Search.reg
download
B) Go to step 3.​
2. To Restore Run
Restore_Run.reg
download
7. When done, you can delete the downloaded .reg file if you like​
  • Replace_Help_with_Search.reg
  • Restore_Help.reg
  • Replace_Run_with_Search.reg
  • Restore_Run.reg
I replaced Run with Search using your reg file on my Dutch OS. That worked fine, I got Search back (in Dutch). Then I changed my mind and decided to put Run back, using your restore file. This failed: I now have neither Search nor Run in the right dark side.
General question: Is it safe to use the register edits on a non-English OS? Specific question: Is there another way for me to get Run back?
Thanks, by the way, for your very clear and useful tutorials.
Hi A.Translator,
Welcome to Vista Forums.:party:
Nice catch you made with the reg file. It was a switch setting in the restore reg file that was set to turn off Run instead of turn on Run automatically. It changed the button back to Run, but left it turned off instead of on. I updated the download to correct this.
You can either check Run again in the Start menu Customize menu, or download the updated Restore_Run.reg file to correct this error.
Sorry about this,
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thanks for your very quick and helpful reply! I should have thought of customizing the Start Menu myself.
In this case it was obviously ok to use your script on a non-English OS. Do you know if this is true of all reg edit scripts?
Usually they will be ok, but I'm sure that there will be one that just does not translate well somewhere. ;)
Just replace the sp1 version of "explorer.exe" with the previous vesion you had before installing sp1 and the search button will be restored without losing any other buttons or modifying the registry.
Log off and back on for the change to take effect.
Hi Dave,
That is a great tip, but you will also lose any other updates to the explorer.exe file from the SP1 with that method.
I suppose it depends on what is more important to the user.
Thank you again for the tip,
EDIT: Very true, explore.exe v.6001 is newer then v.6000 and may have improved seceurity and preformance which should be considered before swaping the new with the old although I haven't noticed any loss of preformance since I replaced it.
On the other hand my guess it's the same file version but modified due to Googles anti-trust legal push to incorperate their search engine into the Micrsoft UI thus making their search a more obvious choice, so shame on Microsoft for backing down to Google in this manner by allowing third party companies to trespass on thier interface. This does a diservice to the end user who should expect more from an operating system. It is my opinion that the user should not be punished for for installing a service pack by losing important service components in what would result in a rollback or even a downgrade.
Hi everyone,
Personally, I don't miss this feature as I have always used the 'Start Search' area on the left hand side of the default start menu. There are options to 'Search Everywhere' and 'Search the Internet' if required.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
From an unbiosed perspective and not to elaborate on the pros and cons of the Right Hand Search Button I could tell anyone who uses it freaquently that my method to restore it is unsurpassed although technically there is a chance that explorer.exe v.6001 may be improved even though it lacks the seach button.
DAVE
Hi Dave,
I'm sorry, but I cannot recommend your method for restoring the button. Your method involves replacing the version of the file installed with SP1 with its predecessor. This is not recommended, as other files which were updated at the same time rely on this file being the correct version as they might not work correctly otherwise. In addition, future updates may require that ALL system files such as these are the SP1 versions (and will probably offer the SP1 update if they aren't), but if some are and some aren't - as will be the case with your method - you might throw up a validation check issue or even a genuine windows issue. It just isn't worth the risk.
Dwarf
    Gigabyte IF233
Brink, if you are concerned about the loss of updates to the explore.exe,I could assure you that the explorer file is a basic file that was modified due to Googles anti-trust legal push to incorperate their search engine into the Micrsoft UI thus making their search a more obvious choice. Shame on Microsoft for backing down to Google in this manner by allowing third party companies to trespass on thier interface. This does a diservice to the end user who should expect more from an operating system. It is my opinion that the user should not be punished for installing a service pack by losing the most important service components to a complete O.S. I have bean able to preform many advanced seaches quickly and conveniantly while retaing the help and support as well as the run box both of wich I cherish. It would be a shame if the custumer had to sacrifice one option for another in what would result in a rollback or even a downgrade. One more thing to add, the procedure I outlined requiers no modifications to the registry. This a definate advantage in order to maintane stability without a needless registry hack that would only reduce explorer's performance.
DAVE
I agree Dave. Shame on Microsoft for backing down on something so trivial.
It is a better option to do what you suggested as long as Microsoft doesn't do any more updates to the explore.exe file, and if the user has not used the SP1 Disk Cleanup Tool already. ;)
Other options are always welcomed to help give folks a choice.
Dwaf, both files are genuine versions of explorer.exe. As for the legality of using one instead of another: I payed for both. The downloading and installation of updates and activation will not be affeccted by replacing one payed-for genuine file with another.
To restore the search button wthout losing the run or help and support button you simply open the start menu and type "explorer.exe" without the quotes in the search box. If the seach says no results [...]
DAVE
Thanks, Dave. I typed in explorer.exe in the search box and it did find it and opened up the Search window, but no button has appeared on the right hand side of the start menu.
Hi Adriana,
Did you also check the Search box in the Start menu's Customize window?
See the second example in this tutorial above for where to do this at.
Hi Adriana,
Thanks for your very quick reply, Shawn. I don't see a Search box in the Customize window.
Well Adriana, the explorer.exe option was worth a try. You can still use one of the options in the tutorial to replace either the Help and Support or Run button with Search instead in the Start menu.
Doh! :o LOL
