Copy as Path - Add or Remove from Context Menu
How to Add or Remove "Copy as Path" from the Vista and Windows 7 Context Menu
This will show you how to add or remove Copy as Path from the context menu for all users on the computer. By default, Copy as Path is added to the context menu.
To see what and how to use Copy as Path, see: How to Copy the Full Path of a File or Folder in Vista and Windows 7
EXAMPLE: "Copy as Path" added and removed from the Context Menu
NOTE:
By default, you must press and hold Shift and right click on the file or folder to see Copy as Path.
METHOD ONE
Using a REG File Download
1. To Add "Copy as Path" to Context Menu
Add_Copy_as_Path_Menu.reg
download
B) Go to step 3.​
2. To Remove "Copy as Path" to Context Menu
Remove_Copy_as_Path_Menu.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
METHOD TWO
Manually Using Registry Editor
1. Open the Start Menu, then type regedit in the search boxand press Enter.​
2. If prompter by UAC, then click on Continue (Vista) or Yes (Windows 7).​
3. In regedit, go to: (See screenshot below)​
Code:
HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\CopyAsPathMenu
4. To Remove Copy as Path to Context Menu
A) In the right pane, right click on (Default) and click on Modify. (See screenshot above)​
B) Clear and leave the field empty and click OK. (See screenshot below)
C) Your registry will now look like this. (See screenshot below)​
D) Go to step 6.​
5. To Add Copy as Path to Context Menu
B) Copy and Past the value below and click OK. (See screenshot below)
{f3d06e7c-1e45-4a26-847e-f9fcdee59be0}
C) Your registry will now look like this. (See screenshot below step 3)​
6. Close regedit.​
  • Add_Copy_as_Path_Menu.reg
  • Remove_Copy_as_Path_Menu.reg
Is there a way to add "Copy as Path" permanently to the context menu so that you don't have to hold down shift in order for it to appear?
Hi Tim,
None that I know of.
Sorry, :(
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
You can add it permanently on the files context menu using clip.exe
For example In HKCR\*\Shell\ you can add the Key: CopyAsPath with value= Copy as Path for example, then from CopyAsPath key, you create a new Command Key with value: %comspec% /c echo "%1"|clip
That should do the job (i can make a reg file if you wish).
I kinda lost here.. could you please create the reg file for us?
here's the reg, make sure the path to the .bat is correct for you...
custompubliccopypath.reg
Code:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shell\copypath]
@="Copy p&ath"
[HKEY_CLASSES_ROOT\*\shell\copypath\command]
@="cmd /c C:\\Windows\\myBat\\copypath.bat \"%1\""
in reg-files, the '\' is qualified, so c:\program files becomes C:\\program files
The batch file (for me, so I can run as command like notepad, mspaint, calc... without path edits) is stored @
C:\Windows\myBat\copypath.bat
copypath.bat
Code:
echo %~1|  clip
If you want, you can put the .bat anywhere... you can put a (shortcut to the .bat) .lnk in C:\windows subdir
(ie C:\Windows\mySysLnks) and change the lnk's properties so it runs minimised (no visible cmd-prompt : )
    Dell XPS L502X
    Intel Core 7-2670QM 2.20GHz
    0NJT03
    8Gb DDR-3 (Samsung)
    NVIDIA
    Realtek HA Audio, Intel (Display) Audio
    Generic PnP Monitor (1366x768)
