Boot Up Time
How to See What Your Boot Up Time is in Vista
To optimize the boot/shutdown of Windows, it is necessary to know precisely the reboot time of the computer to be able to refine its adjustments.
But rather than having the hand on a stop watch at the time of the reboot, better use this easy way, You will appreciate how simple it is to use and the precision of the result.
The relative time value will then give you a point of comparison to optimize the boot/shutdown of your computer.
For fun you can post your results here: ReBoot Time
EXAMPLE: ReBoot-Time dialog box
NOTE:
This is what you will see after running the VB Script file from below and when you computer finishes restarting.
In order to calculate the time of rebooting Windows, we will use a VB Script (Visual BASIC Scripting Edition). Let us learn first how it works.
The script writes a value in the registry (HKCU \ Software \ Microsoft \ Current Version \ run) so that it can be started again when booting. Then, another value containing the time is writen in the registry when the reboot is launched. While rebooting, the script records the hour in a variable then checks if the first value containing the time exists. If so, it is then enough to compare two times in order to obtain the time of rebooting. Then, the two keys added in the registry are removed (the run key and the key where the time is stored).
1) Open your favorite text editor (notepad will do the job perfectly) and copy/paste the following script:
Code:
Option Explicit
On Error Resume Next
Dim Wsh, Time1, Time2, Result, PathFile, MsgResult, MsgA, AppName, KeyA, KeyB, TimeDiff
MsgA = "Please close all running applications and click on OK."
KeyA = "HKEY_CURRENT_USER\Software\RestartTime\"
KeyB = "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\RestartTime"
AppName = "ReBoot-Time"
Set Wsh = CreateObject("WScript.Shell")
PathFile = """" & WScript.ScriptFullName & """"
Result = wsh.RegRead(KeyA & "Times")
if Result = "" then
MsgResult = Msgbox (MsgA, vbOKCancel, AppName)
If MsgResult = vbcancel then WScript.Quit
Wsh.RegWrite KeyA & "Times", left(Time,8), "REG_SZ"
Wsh.RegWrite KeyB, PathFile, "REG_SZ"
Wsh.Run "cmd /c Shutdown -r -t 00", false, 0
else
Wsh.RegDelete KeyA & "Times"
Wsh.RegDelete KeyA
Wsh.RegDelete KeyB
TimeDiff = DateDiff("s",Result,left(Time,8))
MsgBox "Your computer reboots in " & TimeDiff & " seconds", VbInformation, AppName
end if
wscript.Quit
2) Save the file wherever you want on the same HDD (desktop for example) as ReBoot-Time.vbs (you can choose whatever name as far as the extension is ".VBS".
You can also download the script file here:
download < Click to Download
Use of the Script:
  • Double click on the script icon if it is on your desktop or on the file if you saved it in a particular folder.
  • Close all the running applications and click the OK button in the dialog box.
  • The computer will reboot and when Windows will be ready to be used, a new dialog box will open displaying the time your computer took to reboot.
Voila!
  • bootspeed.vbs
You said that this writes a value in the registry then deletes itself from the registry after showing the Reboot Time?
Does it just remake the registry value everytime you use it and delete itself?
Hi McGrady,
When you click OK to reboot, those 2 keys are added to the registry so they are available when the computer boots.
Key A contains the time
Key B is in "run" so the script starts again when the computer has booted
A: HKEY_CURRENT_USER\Software\RestartTime\
B: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\RestartTime
At the end, the script calculates the difference between the 2 "times" and deletes the 2 keys.
So every time you use the script, it does it again and again.
well i got this after i done it:
"Your computer reboots in 64 seconds"
after doing optimization for both cores
"Your computer reboots in 57 seconds"
=D... thats nice! works well!
thats with kaspersky,utorrent,ultramon running at start up!
and i have dual display!
Thanks for great script ..but one question if u dont wants this thn only Delete it or u have to delete it from Registry too????
Hi bmb and welcome to the Vista forums!
If you do not want it anymore, just put the script in the bin.
The registry entries are automatically deleted when the script has finished its job ;)
Sid, I fixed the ones I could this morning ;)
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
I think maybe it was because I was not logged into this site? It worked now and I just got an account on this site. So that might be why and if so, my bad. sorry, forgive me please.
I do know copying the text and pasting it into a word pad file and saving it as stated it messed up my pc and made it not be able to boot. I did it a few times ok and then could not boot. System restore fixed the boot issue and i'm lucky there's a startup repair thing opn my pc that auto starts during boot to fix the issue if you can't boot.
I just downloaded the file and will try that.
sidney1st, awesome looking Dog. I love him/her. I love Dogs.
I tried the vbs file and it worked. I didn't download the new zip you posted. Too bad the hack thing doesn't work for me tho really, :( 4 second difference one time I tried it.
Nice script...this should work the same for XP too correct?
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    Samsung T190 1440X900
    1440X900
    2X Seagate 120 (OS's) IDE
    1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
Thanks and again...nice script
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    1440X900
    1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
I can't get this thing to work. I downloaded it to a folder and closed all open apps and clicked open/run and all i get it the note pad page from the post. What am I doing wrong?
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Hi Bassfisher,
You must have associated .vbs files with notepad, just use Sidney1st`s reboot-time executable instead ;)
download
Steven
