Vista - Drive - Hide or Unhide
Comment
Old 05-26-2008
Brink
How to Hide or Unhide a Drive in Vista
Old 07-09-2009
awargi
Vista Home Premium 32bit
Re: Drive - Hide or Unhide
your a sickkkk guy, its all working..
u know alot aboutt these type of stuff,,
and u reply back quick aswell...
thnx alot for the help mannn.
i will get back if i need further help..
Quote  Quote: Originally Posted by Brink View Post
No problem.
In the left pane, you would right click on Policies, and click on New and Key. Type Explorer, and press Enter.
Old 07-09-2009
Brink
You're most welcome.
Old 07-13-2009
cfoam5
Win7 RC1, Vista Ultimate, XP Pro
Brink,
Excellent tutorial on this subject and much great detail. I have a question and a comment.
1st off what I have found is to hide specific drives, you have to ADD the values together and use that number.
For instance to hide drives E and F it would be this:
E=16 F=32 so 16+32=48 When you place this value, you MUST first select decimal and input the value. When you click ok it is transformed to it's hex value so by inputting 48 decimal I get this value:
"NoDrives"=dword:00000030(48)
Now for my question, I am trying this with Win7 and it isn't working as well. I merge my reg file, I check the registry and it is not changed :-( I am Admin. I logout and Login and the drives that appear in my computer are not as expected but the reg value is not correct. Go figure.. Any Ideas? appreciate any feedback.
Old 07-13-2009
Brink
Hello Cfoam, and welcome to Vista Forums.
Thank you for sharing this.
All Windows 7 questions would get better replies at our sister site Seven Forums instead though.
Old 07-13-2009
cfoam5
OK, I gues I'll have to go signup there too...
One more thing I noticed about this - still looking for info - it also happened on Vista.
You can use group policy settings but they only offer certain drives
You can do the reg entry manual method but are we sure which reg keys get the entry?
HKLM, HKCU, Hum. while trying to track this issue down I searched the reg for the NoDrives entry and nothing came up. OK, Then I went looking manually and guess what I found???
It was there in this key:
[HKEY_USERS\S-1-5-21-1719447127-1121268693-3747253166-1000\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
What the heck is this key and where did it come from. I only have 2 users on the box. Anyway, I had saved the registry before I started messing with this yesterday and now trying to get it back to where I was, I tried to merge it back and it choked - couldn't import file.... WTF?? Any ideas?
Manually searching for NoDrives and deleting hte entry seemed to help, of course running as Admin.
Thanks.
Old 07-14-2009
Brink
Not sure, but I'm happy to hear that it seems that you got it sorted.
Old 09-06-2009
slovenski11
Vista Home Premium x64bit
Unhiding Drives
Hi there!
Im using vista home premium. I found 2 hiden drive without letter.
one is> Healthy (EISA Configuration)
second> Healthy (Primary Partition)
third is C
foruth is D
Can anybody help me about that. I cant unhide thouse drives. I think they are backup drives.
Thank you!!!
Old 09-06-2009
Brink
Hello Slovenski, and welcome to Vista Forums.
If you have a store bought OEM computer (ex: Gateway, Dell, etc....), then these may be your Vista and Applications & Drivers recovery partitions. If they are, then you will not want to mess with them if you ever needed to use them to restore your Vista installation back to factory condition.
Old 09-08-2009
slovenski11
Yes they are recovery partitions, but if i want to recovery system or application how can i do it?
from control panel : backup and restore center?
or do i unhide these partitions?
Thank you again.
And sorry for my bad english. lol
Old 09-08-2009
Brink
Slovenski,
What brand and model is your computer?
Do not mess with these partitions though. Doing so can make them unusable to restore Vista if needed.
Comment
Tutorial Tools
Tutorial Category
How to Hide Drive in Vista and Still Be Able to Use it. Vista hardware & devices
Re: Drive - Hide Vista security
Disable/re-enable or hide/unhide Start Menu in Windows Vista via registry, using VB6 General Discussion
Computer Name - Hide or Unhide in Network Tutorials
Unhide vista c drive Vista hardware & devices
