Vista - Drive - Hide or Unhide
Comment
Old 05-26-2008
Brink
How to Hide or Unhide a Drive in Vista
Old 09-09-2009
slovenski11
Vista Home Premium x64bit
Re: Drive - Hide or Unhide
Hi!!!
My laptop is Toshiba Satellite A300-ST3512
Old 09-09-2009
Brink
Slovenski,
The link below from Toshiba will help show you how to create a set of recovery discs as a backup of your recovery partition in case something happens to it. It will also show you how to do restore the original factory image of Vista like it was the first day you got it.
How to use the Toshiba HDD Recovery Utility
Old 09-09-2009
slovenski11
Thank you very much.
It`s very helpful for me.
Thanks again.
See you.
Old 09-09-2009
Brink
You're welcome.
Old 10-11-2009
jeyessh
Vista Ultimate x86
Hey man!
i had a 5th drive which is hidden now in a laptop!
i can't use the first method as it has HomePremium
and i don't find any explorer under policies
help me regain my fifth drive!
Old 10-11-2009
Brink
Hello Jeyessh,
If this is an external drive, then try disconnecting it and reconnecting it, or restarting the computer to have it back again.
Comment
Tutorial Tools
Tutorial Category
How to Hide Drive in Vista and Still Be Able to Use it. Vista hardware & devices
Re: Drive - Hide Vista security
Disable/re-enable or hide/unhide Start Menu in Windows Vista via registry, using VB6 General Discussion
Computer Name - Hide or Unhide in Network Tutorials
Unhide vista c drive Vista hardware & devices
