Virtual Memory Paging File - Clear at Shutdown
How to Enable or Disable "Clear Virtual Memory Paging File at Shutdown" in Vista and Windows 7
This will show you how to enable or disable clearing the virtual memory pagefile when you restart or shutdown the computer.
By default, this setting is disabled in Vista and Windows 7.
WHY ENABLE:
Sensitive information may have been temporarily stored in the virtual memory pagefile. For this security reason and others, it may be a good idea to enable this setting to clear the virtual memory pagefile occasionally or when you suspect this. When this setting is enabled it will clear the virtual memory pagefile, and the hibernation file only on a portable computer, when you restart or shutdown the computer.
WHY DISABLE:
When this setting is enabled it can add around a minute or so to how long it takes your computer to shutdown and restart. How much time it will add depends on how much RAM you have installed and how big the Virtual Memory Paging File is set at.
C:\pagefile.sys
OPTION ONE
Using a REG File Download
1. To Disable Clear Paging File at Shutdown
NOTE: This is the default setting.​
Disable_Clear_Page_File.reg
download
B) Go to step 3.​
2. To Enable Clear Paging File at Shutdown
Enable_Clear_Page_File.reg
download
5. Click on Run, Continue (UAC-Vista) or Yes (Windows 7), Yes, and then OK when prompted.​
7. If you enabled this setting, then restart or shutdown the computer to clear the Virtual Memory Paging File.​
OPTION TWO
Through the Local Security Policy
1. Open the Local Security Policy.​
2. In the left pane, click on to expand Local Policies and User Rights Assignment, then open Security Settings. (See screenshot below)​
3. In the right pane, right click on Shutdown: Clear virtual memory pagefile and click on Properties.​
4. To Enable Clear Paging File at Shutdown
A) Select (dot) Enabled and click on OK. (See screenshot below step 5A)​
B) Go to step 6.​
5. To Disable Clear Paging File at Shutdown
A) Select (dot) Disabled and click on OK.​
6. Close Local Group Policy Editor window. Your done.​
OPTION THREE
Manually Using Registry Editor
1. Open the Start Menu, then type regedit in the search box and press Enter.​
2. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7).​
4. In regedit, navigate to the location below. (See screenshot below)​
Code:
[/INDENT][/INDENT]
[INDENT][INDENT]HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management[/INDENT][/INDENT]
[INDENT][INDENT]
5. To Enable Clear Paging File at Shutdown
A) In the right pane, right click on ClearPageFileAtShutdown and click on Modify. (See screenshot above)​
B) Type 1 and click on OK. (See screenshot below)​
C) The registry will now look like this. (See screenshot below)​
E) Go to step 7.​
6. To Disable Clear Paging File at Shutdown
B) Type 0 (number zero) and click on OK. (See screenshot below)​
C) The registry will now look like this. (See screenshot below step 4)​
7. Close regedit.​
8. If you enabled this setting, then restart or shutdown the computer to clear the Virtual Memory Paging File.​
  • Disable_Clear_Page_File.reg
  • Enable_Clear_Page_File.reg
but how about I'm already turn off the (0) pagefile
or is it really related?
please advice,shawn
thanks
    XPS 720 RED
    Intel® Core™ 2 Extreme QX9650(Penryn Yorkfield) ([email protected])
    8GB OCZ Reaper PC2-8500 Ver.3@1066MHz
    EVGA GeForce® GTX 295 Plus w/Backplate OC@ 670c/1246m/1500s
    Sound Blaster® X-Fi™ XtremeGamer (D) Sound Card
    Dell Ultrasharp 27" WFP LCD
    1920X1200
    500GB - Seagate 7200RPM, SATA 3.0Gb/s, 16MB Cache with Thermaltake HDD cooler ~
    Western Digital 1TB X (5) / 750GB USB 2.0 My Book Essential Edition 2.0 External Hard Drive
    1,000W
    XPS 720 Sliver w/ X-View Clear Side Panel
    Logitech® diNovo Edge™
    Logitech® MX™ Revolution Cordless Laser Mouse
    15MB~D/2MB~U
    Logitech® Z-5500 THX-Certified 505-Watt 5.1 Digital Surround Sound Speaker System ~
    D-Link DGL-4500 Xtreme N Gaming Router ~
    Scythe KAMA-METER 5.25 inch Bay Multi-Function Panel Controller ~
Abiosis,
No, this is not related to the Index at all. (From post: http://www.vistax64.com/tutorials/69564-index-enable-disable.html#post752202)
This tutorial here will only enable or disable Vista from clearing the Virtual Page Memory file automatically when you shutdown the computer. That's all.
Stopping and Disabling the Windows Search service will completely disable the Index.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
really useful infos
thanks again,Shawn
Peace~
    XPS 720 RED
    1920X1200
    1,000W
    15MB~D/2MB~U
Your welcome Abiosis.
Hello Darkbluetuber, and welcome to Vista Forums.
Enabling this can only increase the boot time if you restart the computer. When this is enabled, the page file will be cleared at every shutdown and restart adding a bit of time for this to finish first.
This will have no effect when starting the computer when it's already shut down or in sleep mode though.
