| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Start Menu - Restore Missing Default Shortcuts How to Restore Missing Default Start Menu Shortcuts in Vista Last edited by Brink; 05-07-2009 at 04:45 AM.. |
| Vista Home Premium 32bit | Thanks for the reply Shawn, I'll give it a try. I've just had my PC repaired, which involved a new motherboard, hard drive and re-install of Vista. The original configuration has therefore been changed. Is there a tutorial which will guide me (a technodork) through reinstalling Vista from my OEM disc? I can't see much on the disc itself. Update on the folder pinning - it didn't work for me. I'm running 32 bit Vista if that makes a difference. I'm leaning more to the reinstall. Martin |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts Martin, What model and brand is your computer? Is it a OEM Recovery disk that you have? |
| Vista Home Premium 32bit | Re: Start Menu - Restore Missing Default Shortcuts Hello Shawn, My PC is made by Evesham Techologies, a (now defunct) UK company. The model is an Oxygen 100. I don't think it is a recovery disk - just a copy of 32 bit Vista. I tried to restore my PC to undo whatever I had done - none of the 4 restore points created since it was repaired worked. I am obviously getting less observant with age. The folder pinning did work but it added them to the "first page" of the start menu rather than the "all programs" page. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts I'm sorry Martin. I thought you wanted to add them to the 1st page (Pin area) of the Start Menu. Option Two in this tutorial below will show you how to add shortcuts to the All Programs area of the Start Menu. Start Menu - Shortcuts Hope this helps, Shawn |
| Vista Home Premium 32bit | Re: Start Menu - Restore Missing Default Shortcuts Sorry Shawn, I'm taking up your time. Since I ran the first lot of pinning scripts I notice I have lots of "desktop - Notepad" files in each start/programs folder, described as configuration settings. When I start my PC, 2 duplicates open automatically with the following - [.ShellClassInfo] LocalizedResourceName=@%SystemRoot%\...l32.dll,-21787 Is there a way I can get rid of them? RSVP Martin |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts Martin, If these shortcuts to these "desktop - Notepad" files are in the Start Menu's Startup folder, then you can just right click on them in the Start Menu and click on Delete to get rid of them. |
| Vista Home Premium 32bit | Re: Start Menu - Restore Missing Default Shortcuts Shawn, There is one on the start/all programs list (mail/media player/internet explorer. The others are in C:\ProgramData\Microsoft\Windows\Start Menu\Programs - Admin/Extras/Maint/Startup folders. The one in startup is the one that pops up when I boot the PC. Is it safe to delete them all? Martin |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts Since you do not want it, then yes it will be safe. |
| Vista Ultimate x64 SP1 | Re: Start Menu - Restore Missing Default Shortcuts I swear... this is a life save... THANK YOU VERY VERY VERY MUCH. i saw a folder in my start menu name "Programs" which basically contained a duplicate start menu. I found that to be rather annoying so i deleted it, wen i restarted i had an empty start menu. So after searching for a way to fix it i found this. saved me a lot of time and headache, <spent two days tryin to "undelete" the programs folder, no luck with that>. THANKS AND Kudos. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts You're welcome xclydes, and welcome to Vista Forums. Shawn |
| Tutorial Tools | |
| Tutorial | Category | |||
| How to Restore the Default Shortcut and Folders in Start Menu....? | Vista file management | |||
| PROGRAM DATA folder suddenly missing, START menu shortcuts don't w | Vista General | |||
| Start menu shortcuts missing, help please. | Vista account administration | |||
| Default Start Menu option missing from Taskbar & Start Menu properties screen | Vista General | |||
| Start Menu Shortcuts | Vista file management | |||
