| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Start Menu - Restore Missing Default Shortcuts How to Restore Missing Default Start Menu Shortcuts in Vista Last edited by Brink; 05-07-2009 at 04:45 AM.. |
| Microsoft Windows Vista Ultimate 64-Bit Service Pack 1 | Re: Start Menu - Restore Missing Default Shortcuts I love you. Thank you very much. That was very useful. Unlike the Microsoft website. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts You're welcome Joseeg12, and welcome to Vista Forums. Shawn |
| Vista Home Premium 32 Bit SP1 | Re: Start Menu - Restore Missing Default Shortcuts THANK Y O U....been trying to figure repair out for days. jakeers |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts You're welcome Jakeers, and welcome to Vista Forums. Shawn |
| Ultimate 32bit | Re: Start Menu - Restore Missing Default Shortcuts Hi Brink, Many thanks for this tute, it works wonders for me, but not for long. It seems after every reboot the icons delete themselves again! I have just done a fresh install of v.Ultimate with no more apps that i used to have one on the previous install (before i had the problem) the only thing different is Nero 9. I have noted you have said a program may cause this to happen, have you any suggestion what type of program may have caused this? or why this may occur? Is this going to be a case of a system restore? Many Thanks, Chris |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts Hello Chris, and welcome to Vista Forums. It could be a number of programs that could cause this. From a registry cleaning program that was allowed to remove registry entries it should not have, or any program that affects the Start Menu shortcuts (almost all of them). I would say that it may be faster to try a System Restore using a restore point dated before this problem to see if it can fix it. Hope this helps, Shawn |
| Ultimate 32bit | Re: Start Menu - Restore Missing Default Shortcuts Thanks for the info Shawn, strage what has happened. Going to try a re-install, i was having some driver issues at the beginning (not encountered before) so will see what happens from here |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts Ok Chris. Please let us know how it went. |
| Ultimate 32bit | Re: Start Menu - Restore Missing Default Shortcuts Hi Shawn/Everyone Clean Re-install worked a treat, this time i didn't experince any driver issues, they just seemed to install. Got all my programs on and this time no issue. I think it may have been when i ticked a box for Shortcuts ALL USERS during an installation process [Poss Nero9]. So thumbs up Thanks for your help |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Start Menu - Restore Missing Default Shortcuts You're welcome Chris. I'm happy that this installation round went smoothly for you. Shawn |
| Tutorial Tools | |
| Tutorial | Category | |||
| How to Restore the Default Shortcut and Folders in Start Menu....? | Vista file management | |||
| PROGRAM DATA folder suddenly missing, START menu shortcuts don't w | Vista General | |||
| Start menu shortcuts missing, help please. | Vista account administration | |||
| Default Start Menu option missing from Taskbar & Start Menu properties screen | Vista General | |||
| Start Menu Shortcuts | Vista file management | |||
