Password - Prevent or Allow to Change
How to Prevent or Allow a User to Change their Password in Vista and Windows 7
This will show you how to Allow or Prevent a selected User Account from being able to change their password from within User Accounts in the Control Panel (Classic View).
By default in Vista and Windows 7, users are allowed to change their passwords.
EXAMPLE: "Windows cannot change the password" Message
NOTE: This is the message a user will get after trying to change their password if their option to change password is set to disabled.
METHOD ONE
Through Local Users and Groups
1. Open the Local Users and Groups manager.​
2. In the left pane, click on Users. (See screenshot below)​
3. In the middle pane, right click on the user account you want to do this with and click on Properties.​
4. To Prevent the Selected User from Changing their Password
A) Check the User cannot change password box. (See screenshot below step 6)​
B) Go to step 6.​
5. To Allow the Selected User to Change their Password
A) Uncheck the User cannot change password box. (See screenshot below step 6)​
NOTE: This is the default setting.
6. Click on OK. (See screenshot below)​
7. Close the Local Users and Groups manager window.​
METHOD TWO
Through an Elevated Command Prompt
NOTE: This method is for all Vista and Windows 7 editions. This method was provided by Dwarf. Thank you Dwarf.
2. To Check the Change Password Status for a User
A) In the elevated command prompt, type the command below and press Enter. (See screenshot below)​
NOTE: Substitute user name in the command below with the user name in quotes that you want to see the change password status of.
net user "user name"
B) To the right of User may change password, you will see either Yes (allow) or No (prevent) for that user name. (See screenshot below)​
3. To Prevent the Selected User from Changing their Password
NOTE: Substitute user name with the user name in quotes that you want to prevent from be able to change their password.
net user "user name" /Passwordchg:no
B) If the command was successful, you will now get a successfully completed message. (See screenshot below)​
C) Verify the change with step 1.​
D) Go to step 5.​
4. To Allow the Selected User to Change their Password
NOTE: Substitute user name with the user name in quotes that you want to allow to change their password.
net user "user name" /Passwordchg:yes
5. Close the elevated command prompt.​
Why is your username not there?
    Hewlett Packard
    3.40Ghz / 2.20Gz Duo Core
    2GB / 3GB
    160 GB / 160 GB
Hi Fmjc001,
It is: User_Name ;)
I made mine to this so folks will know where to look for their user name instead.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Oh, Ok. When i change my username I get all sorts of messages about security errors and policies lol.
Just thought you had a special computer for making tutorials or something :geek:
Thanks for the reply :)
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
I have not had my computer very long and have only had access to the internet for about 2 weeks. my son helped setup the internet and at the same time we changed the password. now both of us have forgotten the password he put in the system. it should not be as difficult to get into the computer as this is proving to be. I do not like Vista. someone needs to think about what the everyday person who will be using the system and make a backdoor of some kind for people like me who have very busy lifes and might forget a stupid password!!!!!!!:mad:
Can you not use another account to change the password?
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
is this possible in all vista versions? when i click on advanced option i got a message saying "this computer is not runing home basc and that this complement can not be used with this version...i ..but my computer is runing home basic
Hi Mike,
My apologies. lusrmgr.msc is only available for the Vista Business, Ultimate, and Enterprise editions.
Here is an addition to the above Tutorial. The method here works for ALL versions of Vista.
Click on the start orb and type cmd into the search box and press and hold Ctrl, Shift and then press enter/return. You will need to provide administrative credentials to continue. At the prompt , type the following: net user dwarf followed by enter/return. Here is what I get for this command:
Notice the line User may change password. This is currently set to No.
Again at the command prompt, type the following and press enter/return: net user dwarf /Passwordchg:Yes. Here is what I get with that command:
Finally, repeating this command: net user dwarf
Notice the line User may change password is now set to Yes.
If you wish to prevent the changing of a password, use this command: net user dwarf /Passwordchg:no
Note that I have used my user name Dwarf throughout this explanation. You will, of course, need to substitute the correct user name here.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Thank you Dwarf. This method has been added to the tutorial to help others.
I opened that window and at the line about changing password is set to yes, but I still cannot change password. When I try to change password I get an error that my current passsword is wrong while it is correct one
Hello L4UR4, and welcome to Vista Forums,
From your other post, see if you can change the password for the log on automatically settings to the same password that you use to log on manually for that user account. You will need to check and uncheck the box (in auto link above) to be able to change the password.
