Vista - System Restore Task - Change Automatic Restore Point Schedule
Comment
Old 07-22-2008
Brink
How to Change the Automatic System Restore Point Settings in Vista Task Scheduler
Old 07-06-2009
Travelin
home premium x64
Re: System Restore Task - Change Automatic Restore Point Schedule
The Desktop Shortcut for Creating a System Restore Point works perfectly. Thanks, it makes manually creating Restore Points much, much easier. Thank you.
Old 07-06-2009
Brink
If you create a new task in Task Scheduler to run the shortcut ("program"), then you will get exactly that.
Old 07-06-2009
Travelin
home premium x64
Great idea! Thanks.
Old 07-06-2009
Brink
You're welcome Travelin.
Old 07-09-2009
pacinitaly
VISTA home prem 32bit SP2 --- XP Pro SP3 32bit
Angry Re: System Restore Task - Change Automatic Restore Point Schedule
Hello again,
mine does not work.
I have not added software or changed any hardware (laptop)
are there any reg files to do the changes?
Old 07-09-2009
Brink
Quote  Quote: Originally Posted by pacinitaly View Post
Hello again,
mine does not work.
It will not create a restore point with this task unless it detects changes on your system to warrant creating one at time of the scheduled task though.
Old 07-09-2009
pacinitaly
Quote  Quote: Originally Posted by Brink View Post
Hello again,
mine does not work.
Thanks Shawn,
Old 07-09-2009
Brink
You're welcome.
Comment
Tutorial Tools
Tutorial Category
System Restore error (create restore point), event ID: 8193 Vista General
System Restore Not Saving Restore Point Vista General
System restore hasn't held a restore point since I installed Vista Vista General
How do I schedule system restore? Vista General
system restore (automatic daily restore points) Vista General
