Vista - Caps Lock Key - Enable or Disable
Comment
Old 08-05-2008
Brink
How to Enable or Disable the Caps Lock Key in Vista
Old 06-28-2009
Annahliar
Vista Ultimate 32bit
Re: Caps Lock Key - Enable or Disable
Quote  Quote: Originally Posted by Brink View Post
You're welcome. Sorry it didn't work in your games.
Hello again, Brink.
I found a way to remap Caps Lock (or any key), not sure if you're interested in making a tutorial about this, but I thought I'd share this information with you. Anyways, instead of doing "00,00,00,00,00,00,00,00,02,00,00,00,00,00,3a,00,00,00,00,00", I did "00,00,00,00,00,00,00,00,02,00,00,00,0D,00,3a,00,00,00,00,00",which basically remapped Caps Lock to "=" (no quotations).
It took me a little while to understand the binary code, but I figured it out pretty quickly.
Here's a link to the website I found this amazing information from: Remap the CapsLock Key or any Key in Windows XP, 2000, Vista and 2003.
Again, thank you for your amazing site and tutorials! Hopefully you'll add this one to your site as well.
Old 06-28-2009
pacinitaly
VISTA home prem 32bit SP2 --- XP Pro SP3 32bit
Quote  Quote: Originally Posted by Annahliar View Post
Hello again, Brink.
thanks
Old 06-28-2009
Brink
Thank you Annahliar,
I'll have a look at that to see what I can come up with.
Comment
Tutorial Tools
Tutorial Category
Notification area/ How to get rid of Caps Lock, Scroll Lock Vista General
Lock the Taskbar - Enable or Disable Tutorials
Caps Lock Off Vista General
CAPS lock / SHIFT lock difficulty Vista General
Lock Computer - Enable or Disable Tutorials
