Vista Tutorial - Sleep shortcut simplified
Comment
IT WORKS!- A very easy way with no problems!
Published by isikh
08-18-2008
Cool
Information
  Hey everyone although according to posts I am a Vista Newbie but I can assure you I am not, but that is besides the point. I really liked the Vista sleep function and wanted a shortcut for it, then someone mentioned this tutorial...Sleep Shortcut However this didn't work for me and many others thus I investigated and found a simple solution!
NOTE
Quote  Quote: Originally Posted by Brink View Post
In my experience with this sleep shortcut, I have found that it only works if you disable hibernation mode first.
Hibernation - Enable or Disable
Reference: Shutdown
Thanks Brink
This is the path for sleep I discovered... %windir%\System32\rundll32.exe powrprof.dll,SetSuspendState
And all u have to do is make a shortcut and viola it works. You will have a shortcut to sleep and you can place it wherever you want to. I tested it; I have the shortcut in my quick launch....if you want to be lazy and don't want to make the shortcut yourself you can do this...for VISTA ONLY! Go to this link and click on Download and Install to download and save this gadget... Windows Live Gallery (This is what I did the first time, it is easy and flawless!)
Then start up the gadget and hit options/preferences.
You will see something that says Vista Quick launch bar, under that it says Add shortcut: there are options for shutdown, lock computer, log off, sleep etc. Click anyone's you want and they will be added to the quick launch and that is it! Any questions or anything ask away! If necessary I will post a picture tutorial too, that is if anyone requests!
Published by
isikh's Avatar
isikh is on a distinguished road
Tutorial Tools
Applies to
All Vista Versions
64 Bit & 32 Bit
Old 08-18-2008
Brink
Administrator
Re: Sleep shortcut simplified IT WORKS!- A very easy way with no problems!
Reference: Shutdown
Old 09-10-2008
robbysondak
Newbie
Vista Home Premium 32-bit
I am used to do this alt F4 - enter (on desktop), to make my laptop sleep.
Old 10-10-2008
hdbg62
Vista Home Premium 32bit
Just found this command for hybrid sleep and it seems to work. Must wake up with the power button on case and everything's on the desktop as when I left it:
rundll32 powrprof.dll,SetSuspendState
Command line hybrid sleep - TechNet Forums
Now, how do I create a shortcut for this so I may use it on the Desktop or in Quicklaunch?
Old 10-10-2008
barman58
Post No Evil ;)
Windows 7 RC x64 Vista HP x86
Smile Re: Sleep shortcut simplified
Hi hdbg62
Just right click on desktop create new Shortcut type the command into the box and click next give it a name , drag to quicklaunch to use it there
Sleep.zip
Old 10-12-2008
hdbg62
I'm a bit confused here. When my computer goes to sleep through power options settings, by clicking sleep in the start menu or clicking sleep after ctrl+alt+del its power button light continues to slowly flash, I can wake it through my keyboard or the power button and all is on my desktop as I left it.
When I put it to sleep through the shortcut (rundll32 powrprof.dll,SetSuspendState) there is no flashing on the power button, I must restart through the power button which it does through the computer startup screen, resuming windows etc., and again all is on the desktop as I left it.
My questions are; are both scenarios the same sleep mode, if not which is what and why does the power button keep flashing under one scenario and not the other?
Here are my advanced settings in power options: sleep after "60 minutes", allow hybrid sleep "on", hibernate after "never"; power button action "do nothing", sleep button action "do nothing", start menu power button "sleep".
Old 10-13-2008
Brink
Administrator
Hi Hdbg62,
Leave your settings as is, but test these settings changes to see how sleep works for you afterwards:
  • Hybrid sleep "off"
  • In the BIOS use the "S3" sleep state
When your computer goes into "sleep" mode it should act like it had shutdown completely, but be instantly woken up with the movement of the mouse or press of a key on the keyboard. You should not have to press the case power button to startup the computer from only sleep mode.
Old 10-13-2008
hdbg62
Scenario is the same with hybrid sleep "off" as in the two I posted depending which sleep button I use. Bios are at S3STR. If I use my shortcut I can only wake it up through the power button (no flashing light, start screen "resuming windows" etc.), if I use the sleep options in startup or after ctrl+alt+del it's the flashing light and I can wake it up through keyboard or power button (mouse has been disabled for that purpose) and it wakens instantly, no "resuming windows" etc..
I don't have a problem with any of it, just would like to know what sleep state I'm in. I guess what got me to wonder is the flashing and non flashing power button plus the different restart scenarios. Is hybrid "on" not the best setting according to your tutorial anyway?
Old 10-13-2008
Brink
Administrator
You would normally only have hybrid "on" if you were using both Sleep and Hibernation mode. Hybrid will allow the computer to go into Sleep mode at first, then later go into Hibernation mode.
As a test, try this Sleep Shortcut .
Old 10-13-2008
barman58
Post No Evil ;)
Hi, hdbg62,
The Sleep/Hibernate setting in vista is linked to the state of acpi in the BIOS. , so that you may get different results if settings in windows and BIOS conflict
you may want to have a look at this description
Advanced Configuration and Power Interface - Wikipedia, the free encyclopedia
Hope this helps
Comment
Tutorial Tools
Tutorial Category
Sleep Shortcut Tutorials
Simplified Chines and Ruby Vista General
Shortcut to logoff then put pc in sleep Vista General
desktop sleep shortcut Vista General
Desktop sleep shortcut ? Vista General
