Internet Explorer No Add-ons - Start Page
How to Change the Default Start Page for Internet Explorer No Add-ons
When you start Internet Explorer (No Add-ons), it loads the default about:NoAdd-ons start page instead of the Home page that you had set for Internet Explorer.
This tutorial will show you how to change the default start page for Internet Explorer (No Add-ons) to what you want it to open to instead.
To open Internet Explorer in No Add-ons mode, open the Start Menu and click on All Programs, Accessories, System Tools, and Internet Explorer (No Add-ons).
EXAMPLE: Internet Explorer (No Add-ons) default start page
1. Pres the Windows + R keys to open the Run dialog, type regedit, and press Enter.​
3. If prompted by UAC, click on Continue (Vista) or Yes (Windows 7/8).​
4. In regedit, go to the location you want below. (See screenshot below)​
For Current User:
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\MAIN
For All Users:
NOTE: The site set for the current user location above will override this one. You must be logged in as an administrator to set this location.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\MAIN
5. In the right pane of MAIN, double click/tap on Extensions Off Page to modify it. (see screenshot above)​
NOTE: If you do not have Extensions Off Page, the right click on a empty area in the right pane, click/tap on New and String Value, type Extensions Off Page, and press Enter.​
6. To Change the Start Page to a Web Page of Your Choice
A) Type in the web address (Ex:Vista Forums), and click/tap on OK. (See screenshot below step 8)​
B) Go to step 9.​
7. To Change the Start Page to a Blank Page
A) Type about:blank, and click/tap on OK.​
B) Go to step 9.​
8. To Restore the Default Start Page
A) Type about:NoAdd-ons, and click/tap on OK.​
9. Close regedit.​
10. If Internet Explorer (No Add-ons) is open, then close and reopen it to see the changes.​
Geez Shawn, where do you find all this stuff?
You need a job writing for MS.
You can delete this, I just wanted to say GOOD JOB ... :party:
Later ;) Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
LOL Ted,
Just from digging around here and there. ;)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
