Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Vista - Firefox Speed Increase
Comment
How to Speed Up Firefox
Published by AlexRD
09-08-2008
This Tutorial to show people how to let Firefox be up to 1.000.000.000 faster !
We are going to change some configurations on Firefox.
What we are going to change, is the amount of requests firefox sents to a site.
What are we going to do is, change the :
-Network.Http.Pipelining
-Network.Http.Pipelining.maxrequests
-Network.Http.Proxy.Pipelining
I didn`t make this Tutorial, i saw on a video on Youtube.
So the Credits go all to Necifix.
Link: YouTube - How to Speed Up Mozilla Firefox up to ONE BILLIONx+ faster!
Lets get Started:
So, type in about:Config in Firefox and then hit Enter.
After it, check the I will be careful, i promise.
___________________________________
Then search:
By default on your Firefox,the valor must be False.
Double-Click it to make it true.
NOTE: If you feel dangerous, don`t worry, if you right click it you can set it to default again.
Then Search:
Then Search:
Network.Http.Pipelining.Maxrequests
So now, you double-click it and choose a valor between 1 - 1.000.000.000 .
(The default is 2 )
VERY IMPORTANT NOTE:
The more you put, the more it uses the bandwith from the site.
If you set one billion, you would be really a pain with the Administrator, and since it is EASY to know who did, you will get banned from that site. So if you want to have Vista Support, don`t do this here. Set it to 150 ( That is a nice number)..
Also, if you set it too high, like 15000 or something like that your Bandwith goes too.
Published by
AlexRD's Avatar
AlexRD will become famous soon enough
Tutorial Tools
Applies to
All Vista Versions
64 Bit & 32 Bit
09-08-2008
Day24
Vista Home Premium 64bit
Leiden, the Netherlands
Re: How to let Firefox 1.000.000.000 faster !!!
somehow I doubt this works. However, Someone should check whether it does. Does someone already have any experience with having changed these settings? can any benchmarks be done to show any actual increase in performance?
I do assume that you mean value where you've said valor.
09-08-2008
AlexRD
Vista Ultimate Edition x64
Brazil
Well, the requests will be one billion, it doesn`t entirely mean that it will be one billion FASTER, but on my computer, when the page comes, (3 - 4) Seconds, it comes with everything loaded. And that is good, because i`m Brazillian , and we have poor networks here, like 2 MB , or 8 MB. =)
( No, i really meant Valor).
You can try that out..
As i already said, if you Right Click it you can set it as default again.
And if you`re afraid it wont start again, you just:
Start>Run> firefox.exe -safemode-
some combination like that on the - .
Alex.
09-08-2008
Day24
Re: How to Speed Up Firefox
As I have a 50 mbit synchronous fibre line, I doubt I will see any improvements, if this works at all.
But let me ask you though. Aren't the changes you are talking about included in the readily available firefox plugin "FasterFox"??? For a lot of people it is far easier to impliment the plugin than these changes.
In any case, You may mean Valor, but I do not think that's the correct translation. I might very well be wrong. In my own firefox, which is the Dutch version, it says "waarde". The translation for that, however, is value.
I have tried the changes you propose, and with my internet connection, I do not see any changes. However, maybe on slower internet connections there might be a difference.
I would like to point people to the warning though. Setting it to a high number (like 1 billion) will probably get site administrators angry with you, which will result in IP bans. Meaning that you might never be able to get on that site again. Just be careful with setting that number too high.
09-08-2008
AlexRD
Brazil
I said on the topic, what you said on your warning
And on my firefox, it is valor xD they must have been wrong translated.
There would be no difference on your network, but in mine it would.
The thing is, with those High Values, the page comes with everything already downloaded, and that is the good thing for me. ( So i have to wait only 4 seconds, and i have everything ).
10-23-2008
mansrm81
Vista Ultimate 64bit SP2
Rockford, IL
Re: Firefox Speed Increase
Thanks AlexRD I set the Network.Http.Pipelining.Maxrequests 150 and thought that was ok then I set it to 200 and the webpages load even better.
12-07-2008
Kavoc
Vista Home Premium x64
I also found that since I don't us IPv6, and from what I've noticed, a lot of others don't either.
network.dns.disableIPv6 Is False. Setting it to True may increase speed as well. Even if nothing more than knocking off it trying to go through 6 before it tries 4.
I'm not sure, but it's a suggestion. Would it help at all?
12-07-2008
jfar
Operating System : Windows (TM) Vista Ultimate Professional 6.00.6001 Service Pack 1
Kildare
Hi, Nice one well done.
12-08-2008
Majkel
Windows 7 Ultimate x64
Legionowo / Poland
I've done every step from this tutorial and after I reopen Firefox the settings are back to default ! can anyone point to me why this happens, how to keep those settings after browser restart ?
12-08-2008
frankzappa77
Vista Home Premium 32bit SP2
I read a tutorial on this subject on a different site and I remember it stating that increasing the value of 'Network.Http.Pipelining.Maxrequests' to anything higher than 8 won't make a difference as Firefox can only hand 8 requests or whatever they are.
I've been trying to find this article for the past 10 minutes but I remember it was something like 'The Truth about ...'.
Anyway, I might be wrong, but great article.
Comment
 Firefox Speed Increase problems?
Tutorial Tools
Similar topics to: Firefox Speed Increase
Tutorial Category
Gmail Imap speed increase! Live Mail
Increase Upload speed? Network & Sharing
How increase the startup speed of Vista Vista General
How to increase speed Vista General
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
