Vista - USB Bootable Vista Installation Flash Thumb Drive
Comment
Old 09-17-2008
Brink
How to Create a Vista Installation USB Key
Old 11-23-2008
Akuanauta
Vista Home Premium 32bit
Re: USB Bootable Vista Installation Flash Thumb Drive
What is retail Vista installation DVD? it's the common dvd of installation of vista, the one that come when we bye an computer??
Yes i have, but is the one that that i create with the recovery manager when i bought my computer, it is vista premium.
Old 11-23-2008
Brink
A retail Vista installation DVD is one that your purchase at a retail store and did not come with your computer. The ones that come with your computer are usually only a OEM Recovery installation disc as in your case, and do not work for this tutorial.
Sorry,
Old 11-23-2008
Akuanauta
So i need to purchase?
It's no use, thank you.
Until the next.
Old 11-23-2008
Brink
Only if you want to create a Vista USB boot thumb drive.
Old 11-23-2008
Akuanauta
Wink Re: USB Bootable Vista Installation Flash Thumb Drive
Bootmgr file it's a miracle
Old 11-28-2008
disturbedfuel15
Vista Ultimate x86 Black Edition 2009
Exclamation To all those using a sandisk u3 flash drive ;)
Quote  Quote: Originally Posted by bratboy1 View Post
Okay I started the process but running into a snag. I get to the step where you type active but when I hit enter I get a message:
"there is no partition selected. Please select a partition and try again"
What am I doing wrong?
I tried following the steps you gave someone else:
diskpart
select volume 9
clean
create partition primary
select partition 1
active
format fs=fat32
assign (note that this changes the USB drive letter)
list volume (to see what the new USB drive letter is)
exit
but when I get to the "clean" command I get the following error mssg:
"There is no disk selected. Please select a disk and try again"
I have the answer you are looking for ! I'll use my given right to assume that you are using a Sandisk Flash drive with the U3 System Installed? I purposely made that part stick out because that is what is causing the commotion for you (I was running into the SAME EXACT PROBLEMS you were having, my friend). You see, Sandisk's pre-installed U3 system is seen as a separate volume on the computer (not your fault ) Does this look familiar?
To whom it may concern,
THE SOLUTION: Uninstall the Sandisk U3 Software
1. Load up the U3 Launchpad (open My Computer, right-click on flash drive, launch U3 software/launchpad; it will still be there after you formatted, cleaned).
2. Close the U3 pop-up window
3. Right-click on the U3 icon in the system tray and click "settings." (see below)
4. Depending on the version of U3 installed on the drive, after clicking settings, you may be greeted with this screen, or a newer one (but the removal actions are still the same). Either check (or click depending on version) "I want to remove the U3 Launchpad (and erase ALL data) on the device".
5. If you have the newer version, another nag screen will pop up (which looks very similar to windows installer if I may say so myself ), once again, warning you that all data will be removed. Simply follow the on-screen instructions by clicking next a time or two, and then finally FINISHED!
6. Using diskpart, you should now see just one volume, instead of two (U3 and the drive itself).
7. Now go ahead and follow the procedures provided to you by the magnificent Brink!
P.S. I can't thank you enough, Brink, for this wonderful website and your (I'm sure) timeless efforts to make this such an outstanding forum.
Take Care & Happy Holidays to All!
Last edited by disturbedfuel15; 11-28-2008 at 11:02 PM.. Reason: Changed Title and Added "Importance Icon."
Old 11-29-2008
bratboy1
vista home premium x32
Nope, wasn't my problem. Ist off I was using Kingston USB drives.
On my XP system no matter what I couldn't get past running the
"Active" command.
When I used my roomys computer, which has X32 Vista installed, I got past that step without a problem but then at the next command
"x:\F:\boot\bootsect.exe /nt60 G:\"
It would rasie a stink about being the wrong type of OS on both machines.XP or Vista x32 boxes.
Once I have a working Vista x64 computer running I think I'll be just fine and will be able to create the drive without a problem. If I wanted a x32 drive I could of gone all the way as is via my roomy's computer but I planned on using x64 and wanted the drive to have the x64 version on it thats where I ran into a snag on both computers.
Old 11-30-2008
VistaKing
VISTA ULTIMATE 32BIT
Brink ,
Can You put both of the versions of Vista x64 and x86 ? For example if I wanted to install either Vista x64 and Vista x86 from the USB FLASH DRIVE . If so how can you do that ?
Old 11-30-2008
Brink
Hello VistaKing,
It's the same method in this tutorial for either the 32-bit or 64-bit Vista, but you cannot do both on one USB drive. It's just that people have had problems when they tried to create a 64-bit USB flash drive from within their 32-bit Vista, or the other way around.
Old 11-30-2008
bratboy1
Quote  Quote: Originally Posted by VistaKing View Post
Brink ,
I don't think its possible to create a dual option install on one USB drive. Has to do with the /nt60 command. The info it creates is different for each version of the OS. You can't even make a x64 bootable USB drive from a Vista x32 system, trust me I really tried, LOL
Your only option would be to buy/create 2 usb drives. One made on a Vista 32 bit system for a bootable install of x32 and a seperate USB drive made on a x64 system to host X64 install.
Comment
Tutorial Tools
Tutorial Category
USB flash drive installation Vista installation & setup
Problem with San Disk thumb drive and vista General Discussion
bootable thumb drive General Discussion
Vista cannot bootup when USB thumb drive is plugged in Vista hardware & devices
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
