| 09-17-2008 | |
| | USB Bootable Vista Installation Flash Thumb Drive Last edited by Airbot; 09-19-2009 at 03:33 AM.. |
| My System Specs |
| 12-09-2008 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive HELP!!!!! Hi anyone, I just got 16GB flash meme and did everything in the instructions and it wont boot!!!!! ![]() I doing anything wrong? |
| My System Specs |
| 12-09-2008 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive You probably did but just in case I have to ask did you enable booting from USB in your MB bios. From the info at top of the guide: "Your motherboard will need to support booting from a USB flash drive. Most newer boards do.
| My System Specs |
| 12-10-2008 | |
Yes I did enable all of that in my bios. And yes a have a retail version of windows vista. Any further help appreciated. Thank you, John |
| My System Specs |
| 12-10-2008 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive John, Some USB flash drives have a extra partition on them that show up as CD/DVD drive in Computer. This is for it's management software. The extra partition will need to be removed before doing the tutorial. The USB software may have a option to do it. If not, then this will show you how to. This will wipe the USB drive clean. Hope this helps, Shawn |
| My System Specs |
| 12-14-2008 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive Hi, i've tried to make a USB Bootable Vista Installation Flash Thumb Drive with no success in the tutorial you say format with fat32 you the end up with a Successfully updated NTFS filesystem bootcode Well when i format with Fat 32 i end up with Successfully updated Fat 32 filesystem bootcode Can someone please explain why this is the case, i've tried both formats and i end up with a filesystem bootcode in which ever format i decided to select, why is it different in the tutorial? Regards Andy Last edited by Brink; 01-28-2009 at 12:37 PM.. Reason: Removed broken image markers |
| My System Specs |
| 12-14-2008 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive Hello Andy, Not sure why. Were you able to boot from the USB key afterwards with it as FAT32? |
| My System Specs |
| 12-14-2008 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive Hi, No i have not been able to boot from any format Fat32 or NTFS. I have followed the guide perfectly and when i restart if i go into bios (F11) and select to boot from usb and press enter, all i get is a blank screen with a flashing under_score in the left hand corner of the screen |
| My System Specs |
| 12-14-2008 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive Andy, Double check all of the items in the Warning box at the top of the tutorial to see if any of it may apply to you. Next, try the steps in the link in the last item listed in the Warning box. |
| My System Specs |
| 01-28-2009 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive Shawn, Is it possible to use an SDHC card of at least 4 GB in capacity instead? Just wondering, because a member has asked this question here: SD Bootable? |
| My System Specs |
| 01-28-2009 | |
| | Re: USB Bootable Vista Installation Flash Thumb Drive |
| My System Specs |
| Tutorial Tools | |
| Similar topics to: USB Bootable Vista Installation Flash Thumb Drive | ||||
| Tutorial | Category | |||
| USB Flash Drive Installation Kits | Vista General | |||
| USB flash drive installation | Vista installation & setup | |||
| Problem with San Disk thumb drive and vista | General Discussion | |||
| bootable thumb drive | General Discussion | |||
| Using a Flash USB thumb drive to speed up performance? | Vista installation & setup | |||
