Vista - USB Bootable Vista Installation Flash Thumb Drive
Comment
Old 09-17-2008
Brink
How to Create a Vista Installation USB Key
Old 01-28-2009
bratboy1
vista home premium x32
Re: USB Bootable Vista Installation Flash Thumb Drive
Okay I finally was sucessful in making a boot usb drive with Vista x64 on it, now a quick question.
After I boot up and run a clean install when Vista wants to do the first reboot do I need to change the bios as the system reboots or just unplug the usb drive so that it will look for USB not see it and then proceed to boot using the HD?
Old 01-28-2009
Brink
Bratboy,
You can change the BIOS settings when installation is done and after you get the "Preparing desktop for the first time" screen.
Old 01-28-2009
bratboy1
Ah okay so set bios to boot from USB - start up run the install, let it reboot(still set to boot from usb device and leave the USB drive connected let it reboot) then after the install is completly done THEN reboot and change the boot order in the bios.
Did I get that right? I was afraid if I left the usb enabled it would just try to rerun the install again hehe
Old 01-28-2009
Brink
Yep you have it right. During installation it will still need to access the USB drive to finish installing Vista.
Old 01-28-2009
bratboy1
Cool, hopefully the darn thing doesnt die like one of my Corsair FlashVoyages 16 gig units did but nice to have the drive as a backup to the DVD
Old 02-20-2009
kiddieboy12
Vista Home Premium 32bit
can i delete it afterwards?
Old 02-20-2009
Brink
Hi Kiddieboy,
Sure you can format the USB key whenever you like and use it as you like.
Old 02-20-2009
kiddieboy12
but..but..i forgot
Old 02-20-2009
Brink
What do you mean Kiddieboy??
Old 02-20-2009
kiddieboy12
like u right click on the drive rite? select format.
Comment
Tutorial Tools
Tutorial Category
USB flash drive installation Vista installation & setup
Problem with San Disk thumb drive and vista General Discussion
bootable thumb drive General Discussion
Vista cannot bootup when USB thumb drive is plugged in Vista hardware & devices
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
