Vista Tutorial - USB Bootable Vista Installation Flash Thumb Drive
Comment
Old 09-17-2008
Brink
Administrator
Vista x64 Ultimate SP2, Windows 7 (7600) x64
How to Create a Vista Installation USB Key
Old 06-06-2009
Brink
Administrator
Re: USB Bootable Vista Installation Flash Thumb Drive
Hello Nonpasaran,
In addition to The Cool Guy's post, doing a installation from a USB key that uses the USB 2.0 standard will install much faster than from DVD.
Old 06-11-2009
rschap1
Newbie
Vista 32
I was lead here by Vista's tech support and told to make a USB bootable "Anytime Upgrade" disc. I had followed the instructions at the beginning of this thread, loaded my Disc, downloaded UltraISO and so on, somehow I couldn't get the disc to be read. Any ways, I have since done a full recovery on my machine that I needed the USB bootable for. Finally that is done. Now I would like to get the .ISO files off my USB drive and be able to use it as I did previously. Everytime I try to plug it in to erase these files, it seems as though it is freezing and crashing the machine I plug it into. I have tried 4 different machines now. I did get one to show that the files were read only and could not be removed. How do I get these off of the USB flash drive??? THANKS
Old 06-11-2009
Brink
Administrator
Hello Rschap1,
Check to see if your USB key as a switch on it that makes it read only or not. Some include this feature.
Next, try METHOD ONE in this tutorial below to see if you are able to delete the USB key, then be able to format it and use it as normal. If not, then I have a more involved method that should work for you instead.
Disk Management - Delete and Extend
Old 06-11-2009
rschap1
Newbie
Vista 32
Thanks very much for that info. The flash drive does not have any type of switch on it. I had tried to access the drive by opening the UltraISO program, File NEW, and trying to explore the flash drives contents, hoping to erase them that way. That is when I got the read only error message. Was there something else in Method 1 that I did not pick up on? Also, looking at the link to extending or removing partions from drives, is this to say that I can use Disk Managment to extend or delete the drive and that will clear the drive of it's contents or format it? Appreciate the help. THANKS AGAIN!
Old 06-11-2009
Brink
Administrator
Rschap1,
You would want to see if you are able to delete the USB drive in Disk Management, then format it to hopefully be able to use it normally again.
Old 06-17-2009
hclarkjr
Senior Member
Vista ultimate 64 bit SP2
brink, i tried booting with F12 instead of changing it in bios and it did not work. why does it need to be changed in the bios? doesn't F12 do the same thing?
Old 06-17-2009
Brink
Administrator
Hello Harry,
I've always set in the BIOS to make sure that it boots to the USB key. I haven't tried using F12 before though.
Old 06-17-2009
hclarkjr
Senior Member
i am wondering if my motherboard will not boot to flash drive? i tried with it set to USB FD and USB HD, it sets there about 5-10 seconds then loads windows normaly.
Old 06-17-2009
Brink
Administrator
I have a Gigabyte motherboard, and it has two separate settings for the boot order. One for the "Hard Disk Boot Priority" and another for the "1st, 2nd, 3rd, Boot Device". If your's has something similar, then you will need to set both of them for the USB drive. You may also need to try the different USB (ex: FD, HD) options to see if one may work instead of another.
Old 06-17-2009
hclarkjr
Senior Member
thank you, i will look into those
Comment
Tutorial Tools
Tutorial Category
USB flash drive installation Vista installation & setup
Problem with San Disk thumb drive and vista General Discussion
bootable thumb drive General Discussion
Vista cannot bootup when USB thumb drive is plugged in Vista hardware & devices
Using a Flash USB thumb drive to speed up performance? Vista installation & setup
